The all DHT SET Headphone Amp
Old 4th February 2013, 06:53 PM   #201
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
Could be a tap, though I should say that having its own trafo is not overdoing it! Even with CCS loading, the silence of the power supply is of top importance.
Shunt regulator is good value in a stage that only draws 7mA - the overall regulator dissipation can be modest.
Old 4th February 2013, 07:12 PM   #202
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
I found 3A5 not that linear when swinging lots of voltages, good for low level signals though.
How many volts are you looking the 3A5 to swing?
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 4th February 2013, 07:17 PM   #203
Pano is offline Pano  United States
Pano's Avatar
The 4P1L has a gain of about 10 in my output stage, so take that as a starting point.
Old 4th February 2013, 07:29 PM   #204
mogliaa's Avatar
You can try it yourself. Here is the spice model I created for the pair of 3A5 triodes in parallel:
http://www.bartola.co.uk/valves/2013...dht-continued/
Don't want to be the bearer of bad news, but 3A5 is better suited for low signal (e.g. Preamps, etc.)
Ale
Old 4th February 2013, 07:37 PM   #205
iko is offline iko  Canada
iko's Avatar
I'm in agreement with Ale on this one. I've considered 3A5 for a long time for input duty, and it's excellent as long as you don't feed it too much swing. Plus, I don't see anything wrong with driving the 4P1L output with a triode connected 4P1L. Should work for most headphones at volumes that your ears will be sore. Different story for a power amp. Pano, which headphones exactly are you planning to use?
Old 4th February 2013, 07:58 PM   #206
45 is offline 45  Italy
45's Avatar
Ale
Used as input in a 3 stage amp should be fine otherwise I tried to say this implicitly some posts ago talking about the ECC40.
Old 4th February 2013, 09:49 PM   #207
andyjevans is offline andyjevans  United Kingdom
The 3a5 is a very decent sounding DHT but not a great one. Another similar mu one is the 1J6 - it has a fuller and meatier sound. The sections are not usually too well balanced, however. It can sound good. But not in the class of the 26 and 4P1L to my ears. I've used all these.
Old 4th February 2013, 10:45 PM   #208
jpak is offline jpak  United States
jpak's Avatar
Originally Posted by ikoflexer View Post
Two stages, both with 4P1L would be just fine IMHO.
Pano says it has a gain of 10. IMO that is quite high for the very efficient Sennheisers. For reference I have a Beta22 here with voltage gain of 6, and with my 2vrms output DAC I am rarely past 10 o'clock on the volume.
I'm using Pete Millet's calculator to gauge output levels. It doesn't seem like I will need more than 300 mw of output, I'm trying to keep the transformers as small as possible and considering using custom wound Electra-Print or Sowter.
Old 4th February 2013, 10:51 PM   #209
Pano's Avatar
Sennheiser HD580. Nominally 300 ohms. I can drive them to quite satisfactory levels with a 25:1 OPT terminated with 8 ohms and the headphones. They won't knock your ears off, but for most materials it's plenty loud.
Some of my lower impedance cans, like JVC, don't get as loud at the same setting.
Take the Speaker Voltage Test!
Old 4th February 2013, 11:14 PM   #210
iko's Avatar
And you want higher gain so that you can use your existing transformer into an 8R load?
The all DHT SET Headphone AmpHide this!Advertise here!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 11:46 AM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 08:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 09:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 02:54 PM
