The all DHT SET Headphone Amp
Old 31st January 2013, 11:25 PM   #101
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by merlin el mago View Post
More or less what's the consensus schematic or ideas to make the headphone amp?
After consensus about voltages and powers to drive headphones.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 31st January 2013, 11:49 PM   #102
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
is there such a thing as 'autoformer-cathode-output' ....(single ended) ?
Old 31st January 2013, 11:57 PM   #103
iko is offline iko  Canada
iko's Avatar
What do you mean?
Old 1st February 2013, 12:02 AM   #104
I mean using autoformer instead of normal OPT
and connect to cathode for low impedance
and maybe this way use ordinary toroid with good result
I know it could work as a circlotron design, but could it also be done as single ended ?
Old 1st February 2013, 12:13 AM   #105
I guess not
might be more like autoformer phase splitter
I guess it's back to ccs parafeed....with autoformer output
Old 1st February 2013, 12:50 AM   #106
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Let's set the requirement for power output to be 2W, and the ability to drive all headphones. The voltage swing issue can be dealt with by selecting the right transformer.
Old 1st February 2013, 01:05 AM   #107
iko's Avatar
2W into 8 ohms?
Old 1st February 2013, 01:16 AM   #108
Originally Posted by ikoflexer View Post
2W into 8 ohms?
2W into any impedance via impedance matching. The 4P1L tubes can do it.
Old 1st February 2013, 01:37 AM   #109
stajo is offline stajo  Sweden
Good for you, if you have the demands. Take care of your ears,
Staffan
Old 1st February 2013, 01:55 AM   #110
Originally Posted by stajo View Post
A normal amp.
The gain would be too low to power speakers. With another source of gain, then it can.
The all DHT SET Headphone AmpHide this!Advertise here!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 12:46 PM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 09:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 10:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 03:54 PM
