The all DHT SET Headphone Amp - Page 81 - diyAudio
Old 9th August 2013, 06:17 PM   #801
merlin el mago's Avatar
I have to ask Edcor about DC current, I will let you know. Thanks for your advice about cheap OPT.
Old 9th August 2013, 10:39 PM   #802
Iko, 80mA.
Old 25th August 2013, 12:47 PM   #803
regal is offline regal  United States
A great suggestion was sent to me by Lauscher to use 6A3's or equivalent in filament bias with the coleman regs for the output tubes.
I've been considering this and here are the pro's and con's:
Pros:
Gets rid of the big bypass cap.
Less heatsinking required for coleman regs
NOS tubes are much cheaper and easier to come by
Cons:
The Ra raises over 1k ohms which saps power and power delivery.
Less flexibility with output transformer due to the higher Ra.
Higher Filament voltage may mean more noise, of course with a DHT headphone amp noise is the greatest challenge.
I think I am sticking with 2A3 for now, almost think PSE 4p1L's would be a better choice if you must have filament bias than the 6A3. But for ultimate power PSE 6A3's in filament bias may be the ticket over a 300B.
Thoughts?
Old 25th August 2013, 07:15 PM   #804
to get a good sound from a DHT tube with DC filament, you have to decouple the music signal from the DC supply.
- conventional CLC supply and then a 0,2H to 0,5H choke before the filament. A CRC supply will generate a lot of heat with 1A - 2,5A.
- the reg. from Rod Coleman are no usual voltage or curent regulators. They sound so good because they separate the signal from the DC supply.
On my 300B amp there is no noise on my 101db speakers. Headphones are much more sensitive. I suggest send a pm to R. Coleman. He is verry helpfull and has a lot of theoretic and practical experience. His kits are not expensive. You can not use them with a simple 10,000F cap in front. With a CLC you get them silent.
The input voltage must be 6V-7V higher than ouput voltage. It dissapates more heat if you use 2,5A instead of 1A.
The Ra does generaly rise when you use filament bias, because you remove the cathode capacitor.
Ra total is=Ra+(mu+1)xRcathode
Your OPT has 5KOhm, so 1K Ra is no problem. Usual formula for OPT is 3 to 4 times the Ra. For the Hifiman HE-6 you need a lot of damping. PSE with 4P1L is one solution. Plus you have a lot less heat dissipation in filament bias than with 6A3/6B4G/6C4C.
If you want low Ra, then use 6C33.
Johann
Old 17th May 2015, 01:31 AM   #805
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Rod Coleman View Post
Never!
A compound triode - bipolar stage, with a 2nd-order dc bias controller, to give zero dc offset, no output capacitor at all.
I'll finish drawing it, if there's interest.
I had similar thoughts several years back - has anybody built it ?
SET amp using Triode-FET complementary feedback pair ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 12:46 PM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 09:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 10:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 03:54 PM
Copyright 1999-2017 diyAudio
