#71 |
Probably so. I didn't look at the PS. I was just changing the amplitude of the input.
#72 |
And if you can't find a HV shunt reg that can do 260V output here's what I use. It'll be very quiet and outstanding output impedance. You do need to know what you're doing to get a good pcb. More info about it you can find in this following old thread HV shunt regulator
#73 |
No the SSHV2 is good to 450V, when you DC couple it just makes since to use a tube for the first stage that operates linearly at a lower plate voltage, when you DC couple B+ is the addition of the first tube's plate, the second tubes plate, and the second tube's cathode. So 260V isn't the issue, over 450V is the issue.
I guess I wouldn't give up on DC coupling, especially since I showed how to filament bias the output tube. This gives the minimum caps in the signal path (first and second tube filament biased and no coupling cap.) |
#74 | |
#75 | |
#76 |
For DC coupling why not stack two SSHV?
#77 |
I guess I don't see the need, the input tube will would not be powered by the SSHV because it would have a CCS or gyrator. If we use a negative supply for the input tube to enable a dc couple then we need to add a coupling cap at the input, so no benefit.
I think what I posted a few pages back makes the most sense and has no practically no caps in the signal path. I'll add detail to it and attach the asc file this weekend. |
#78 | |
Can anyone else cast some light on this? |
#79 |
You can't get rid of the cap across the 4k3 resistor if you want the tube to properly amplify the signal. If you want to get rid of that cap you need a stacked supply. Then the 4k3 resistor also disappears. Which also makes the filament bias useless. So, if you want DC coupling then you either to the resistor plus cap, and the filament bias is useless IMHO, or you have a stacked supply, and the filament bias again brings nothing to the table.
Myself, not sure how much of a fan of DC coupling I am... is the effort and complications worth it? |
#80 | |
45 Last edited by 45; 31st January 2013 at 05:32 PM. |
| High end Ortho Amp on a basic Russian Tube DHT SET DIY design | regal | Headphone Systems | 2 | 7th December 2012 11:46 AM |
| 300b all-DHT SET | andyjevans | Tubes / Valves | 16 | 24th August 2012 08:06 PM |
| Help on designing full DHT SET power amplifier | milen007 | Tubes / Valves | 56 | 11th August 2011 09:38 PM |
| Class A, DHT driven, headphone amp | iko | Headphone Systems | 100 | 26th March 2011 02:54 PM |
