The all DHT SET Headphone Amp - Page 52 - diyAudio
Old 16th February 2013, 02:10 PM   #511
merlin el mago's Avatar
Originally Posted by regal View Post
Fixed typo in chart post #508 had a typo. Added 6sn7-307a
Are you sure 1V 8%?
Old 16th February 2013, 02:27 PM   #512
regal is offline regal  United States
Thanks Merlin, fixed. Also to much regret as I despise 6DJ8's due to their cost and sometimes sound they're showing a perfect match for the 307A, the distortion is exponentially lower than the other tubes, I hesitate to post yet. The 307A is proving to be a tube that doesn't quit, low distortion low level to very high level.
Old 16th February 2013, 02:28 PM   #513
Wich one is the 307A triode connected grid?
-supresor
-screen
-control
Old 16th February 2013, 02:29 PM   #514
I have a couple of excellent E88CC Russian military, please could you do the simulation?
Old 16th February 2013, 02:31 PM   #515
-supresor
-screen
-control
I am just using a triode model that Iko posted as the purpose of these comarisons are just meant to be relative and determine gain structure of the amp, I believe Control is connected to the grid.
Old 16th February 2013, 02:32 PM   #516
Pano is offline Pano  United States
Pano's Avatar
Sure would be nice if someone would build something.
Otherwise, this will become another "Beyond the Ariel" thread.
Old 16th February 2013, 02:41 PM   #517
My build is at least 3 months away as that it typically what companies are quoting for the custom transformers. One thread mentioned that a we are considering took a year to deliver transfo's. I want to make dam sure I am set on the tubes /topology before I order $1k worth of iron.
Old 16th February 2013, 02:50 PM   #518
Before that happens, a solution has to be found to the transformer problem. Working with loads with Z ranging from 8Ω to 300Ω, or even 8Ω to 64Ω, without sacrificing sound quality, is somewhat beyond an ordinary amp project. There are too many variables, and at least most of them have to be eliminated before starting building, otherwise it will easily become a blackhole for time, money and motivation.
Old 16th February 2013, 02:59 PM   #519
I think a topology/transformer that can deliver a clean 1W into 38 ohms and you have a transformer that will work with 99% of all headphones. If you do the math a parallel resistor for the high ohm phones which are almost all super efficient will be better than a frankenstein transfo with 10 different secondaries.
If we could figure out this balanced drive thing with two secondaries and what the ratio comes out to we could robably even have a nice little speaker amp.
Old 16th February 2013, 03:10 PM   #520
Pano's Avatar
OK, not my cup of tea, so I'll leave you alone and get back to the 4P1L thread. I've already built, measured and listened to an all DHT-SE headphone amp. Not perfect, but at least real world stuff that tells me a lot.
Since this has turned into a search for the perfect transformer, I really don't have much to contribute. Guess I just get impatient will all the sims and talk, sorry. Too many threads turn into nothing more than talk. I want to solder stuff!
Take the Speaker Voltage Test!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 12:46 PM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 09:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 10:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 03:54 PM
Copyright 1999-2017 diyAudio
