The all DHT SET Headphone Amp - Page 12 - diyAudio
Old 1st February 2013, 02:48 AM   #111
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by tinitus View Post
I mean using autoformer instead of normal OPT
and connect to cathode for low impedance
and maybe this way use ordinary toroid with good result
I know it could work as a circlotron design, but could it also be done as single ended ?
Sure it can.
See my previous pictures.
The Devil is not so terrible as his math model is!
Old 1st February 2013, 03:58 AM   #112
12B4A is offline 12B4A  United States
12B4A's Avatar
I don't know where the circuit design is going but I have a good idea for the chassis:
Old 1st February 2013, 04:53 AM   #113
Wavebourn's Avatar
Camel is a horse prototype designed by big team.
Old 1st February 2013, 09:48 AM   #114
I think things will become clear when a few of us actually build working models of an all-DHT headphone amp. Yes - they will be different, but all should work! That's what we found with the 26 preamp thread. It started off as theory and by now I wouldn't be surprised if there as many as a hundred working examples. They fall into distinct categories - active load, plate choke, transformer coupled - and people build what they can afford and are comfortable with.
I'm sure Sowter can provide a transformer solution, but I'm expecting that some of us will be looking for cheaper alternatives as well. We haven't talked about the ratio of headphone to speaker listening either. In my case I never use headphones, though I do have them.
Old 1st February 2013, 12:45 PM   #115
regal is offline regal  United States
how about 'the ordinary' 2A3 ....parafeed ?
I am leaning in this direction. Dsvavitz has some real good point on his website in support of Parafeed for headphones. The ability to use a permalloy core really is a benefit for headphones, first its better with low level signal integrity/loss, and second most importnt you don't end up with a secondary 32 ohm winding with 12 ohms DCR and too much induction.
I asked Magnequest to quote their 2A3 nickel parafeed with a 32 ohm secondary months ago, with nothing, they just aren't interested.
I think this little transformer parafeed could be the way to go: Sowter Type 8650 Headphone Output transformer
It only handles 0.5W at 20 hz, but is good for 2W at 50 Hz, if it was the next core size up it would be perfect for a 2A3 or parallel 4P1L's.
Very well said. I respect all input on this as we are treading new ground.
What is your opinion on parafeed?
Old 1st February 2013, 01:17 PM   #116
12B4A's Avatar
Well, with just single stage 26 alone I am able to drive my own headphones beyond my comfortable listening level but they are 100dB+/mW efficient (Sony 7506s). I was using a parafeed MQ EXO-45 (1uF motor run cap) in the test circuit and now I'm waiting for Edcor to ship EDCOR - PCW10K-7K/300-32 which would allow for better impedance matching. It certainly wouldn't drive Orthos well but it is dead quiet and would work very well for nearly every other headphone from high 90's sensitivity and above. I think one aspect of the goal of this discussion that has been missing is that can a DIY'er buy the parts for this design with off the shelf components that are not 'the most exotic' in the world? So far, Rod's and Iko's circuits seem to fit that particular concern.
Old 1st February 2013, 03:24 PM   #117
merlin el mago's Avatar
The Edcor can drive 97dB/mW of Sennhs HD600 with only 0,5W?
Old 1st February 2013, 03:34 PM   #118
12B4A's Avatar
I haven't tried but why wouldn't it? If 1 milliwatt produces 97dB then what is 500 milliwatts going to produce? Permanent hearing loss is my guess.
Old 1st February 2013, 04:17 PM   #119
Pano is offline Pano  United States
Pano's Avatar
And broken headphones.
Old 1st February 2013, 04:25 PM   #120
I checked Edcor site and doesn't have in stock "Product is built to order.", do you know how many time takes to build & deliver?
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 12:46 PM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 09:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 10:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 03:54 PM
Copyright 1999-2017 diyAudio
