#91 | |
Merlin would like the lot choice. 600, 400, 200, 100, 50, 25. What does Sowter has to say about that? |
#92 |
If possible also 300 ohms.
#93 | |
try this to get us back on track... 4P1L | Bartola Valves I found it looking up the tube the OP was gonna use, scroll down for lots of info... dennis h |
#94 |
I did a few listening test on my Beyer DT931. They are speced 600+ something. They are harch and twisty on that level and I prefer 200ish to my taste... Headphones is headphones. They are all designed (except some mentioned) to the common 200 ohm clausule.
Have anyone tried old tube radio OPTs? With maybe some lack in lower region I think they outperform newish stuff. Staffan |
#95 |
funny, Bartola's site looks like DHT Rob's new site
anyway, since a real SRPP preamp is said to be optimal only when designed for a specific low impedance load, I thought it would be ideal for headamps ? |
#96 |
Staffan, I build things for myself, so my design goals are usually related to what I have. However, it's not too difficult to change a schematic to accommodate a higher impedance set of headphones. For myself I intend to wire my own output transformer if I can't find something reasonable to buy.
As for the topic, I think we're still on topic. As is the case with every thread, not every posting will be a schematic or comments on that schematic. Human nature... |
#97 |
More or less what's the consensus schematic or ideas to make the headphone amp?
#98 | |
/Staffan |
#99 |
how about 'the ordinary' 2A3 ....parafeed ?
#100 |
| High end Ortho Amp on a basic Russian Tube DHT SET DIY design | regal | Headphone Systems | 2 | 7th December 2012 11:46 AM |
| 300b all-DHT SET | andyjevans | Tubes / Valves | 16 | 24th August 2012 08:06 PM |
| Help on designing full DHT SET power amplifier | milen007 | Tubes / Valves | 56 | 11th August 2011 09:38 PM |
| Class A, DHT driven, headphone amp | iko | Headphone Systems | 100 | 26th March 2011 02:54 PM |
