Music Angel XD 500 MkII Bias setting
Old 25th January 2013, 01:01 AM   #1
rotaspec is offline rotaspec  New Zealand
Default Music Angel XD 500 MkII Bias setting
I have a Music Angel XD 500 MkII amp that is used as backup to my main system. I have never re-biased it since I bought it used, 2 years ago, and don't know the setting I should see on the EL34's.
Tubes are Ultron (RFT) EL34. All test fine and matched on the Avo tester.
Help would be much appreciated.
Gary
Old 25th January 2013, 01:44 AM   #2
HollowState is offline HollowState  United States
HollowState's Avatar
If you searched this site, you would find stuff like this. If you have 22 ohm cathode resistors, you want to read about 0.88 volts across each one to give 40mA quiescent current per tube.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Music Angel XD 500 MkII Bias settingHide this!Advertise here!
Music Angel XD-850MKIII 300b integrated amp mjaymc Tubes / Valves 18 30th August 2015 01:54 PM
Bias help Music Angel L$, EL84 Edriz Tubes / Valves 18 20th November 2012 06:24 AM
Music Angel XD-SE EL34 Amp knutech Tubes / Valves 0 22nd May 2011 01:06 PM
Music Angel XD-SE EL34 intermittent thump kyleaudio Tubes / Valves 4 13th April 2011 09:59 PM
Music angel XD-SE EL34 Kippy Tubes / Valves 18 12th January 2011 09:36 PM
