Hello
Must have a little help from the United States.
I have some 22KM6 that I want to play with. But but but. Where can I find a socket for this tubes.
A European magnoval socket does not fit because the pins on the tubes are too thin. Just bought 4 American sockets on ebay with the same error.
Solutions?
Benny
Denmark
Solutions?
Benny
Denmark
What you want is 9 pin "novar" sockets. Not magnoval.
Pairs of 9 Pin Novar Hard to Find Compactron Socket Tube Radio Tester Amps TV | eBay
This is magnoval and do not fit the thin pins. I have some on stock.
Benny
Benny
Did you read this ?
"These will work with either novar (.040 diameter pins) or magnoval (.050 diameter pins) tubes, however once a magnoval tube has been inserted the pins will likely be too loose to use with the smaller novar pins."
- Tubes / Valves
- Magnoval
