| diyAudio Sponsor | ||
I'm using an AZ1 rectfier for my cd enhancer II http://www.ultranalog.com/cdenhancer...ancer2_3a5.pdf After the choke (i'm using a 10 H 100ma), is there a limit to how much capacitance one can use? I know the specs state 60uf and 60ma max. I have recently added a couple of polpy-p bypass caps (4.7uf each to this cap) after the choke and resistors on the circuit, I may be wrong but it appears the filament is a bit hotter (brighter red). Also what happens when 2 equal valued chokes are put in // ? I asume that the dc resistance halves, but what about the rating in Henry's, and also the added load if any to the rectifier tube? (I ask as there are some quite cheap but reasonable chokes available over here so using another as well is not too expensive). Thanks raja |
#2 | ||||
diyAudio Senior Member
Frank |
#3 | |
Any clues as to how to use the chokes 'differently'? Thanks Frank Raja |
#4 | ||
You now have a CLCRC filter, you could turn that into a CLCLC one. If you feel like experimenting, you can also put chokes in the ground line. Cheers,
Frank |
#5 |
> DCR would divide by the number of chokes, inductance would be the same as for a single inductor.
Inductance would be half, no? That is assuming no magnetic coupling. With iron-core chokes, there won't be enough coupling to screw-up power supply estimates. For the 3A5 plan, a 100mA choke seems way over-sized. Two in parallel don't make any sense. Does it hum? Unlikely with those cap values and push-pull output. I don't see any point in messing with the chokes. |
#6 | ||
Frank |
#7 |
Okay okay, I get the message,
Thanks for the info though! Raja |
| chokes, caps, and long distance relationships | cbutterworth | Tubes / Valves | 3 | 3rd October 2007 05:54 PM |
| Rectifier snubbing caps ? | AndrewT | Power Supplies | 3 | 1st August 2006 06:13 PM |
| Mesa Dual Rectifier Mods...caps? | ttrentt | Instruments and Amps | 9 | 23rd June 2006 03:39 AM |
| rectifier board not working after putting on bypass caps. | demogorgon | Chip Amps | 19 | 8th December 2004 11:31 AM |
| Rectifier caps? | supernet | Everything Else | 2 | 27th June 2002 06:48 PM |
| Page generated in 0.10291 seconds (81.09% PHP - 18.91% MySQL) with 10 queries |
