SE EL34 in triode schematic - diyAudio
Old 24th January 2013, 06:16 AM   #1
Default SE EL34 in triode schematic
Heyo
I'm looking for a tried and true basic build, very simple, of a singled ended EL34 in triode (true triode?) schematic using little to no negative feedback. Basically trying to build a budget SET 2A3 amp. I have decent iron.
Any ideas?
Cheers~
Old 24th January 2013, 06:57 AM   #2
jim is offline jim  Belgium
I've build this amp : EL34(T) SE AMP and I'm very pleased with it! And very easy to build.
Old 24th January 2013, 04:48 PM   #3
nice one thank you. what language is the website link in?
Old 24th January 2013, 07:30 PM   #4
It's in japanese! Google translate will help.
Old 25th January 2013, 12:29 AM   #5
boywonder's Avatar
Have you checked out the tubelab simple single ended? Can run triode or UL, cathode bias, etc.
Tubelab George sells PCBs for this circuit and has a dedicated forum here, so lots of support.
Tubelab Home
Tubelab - diyAudio
Old 25th January 2013, 01:03 AM   #6
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
2A3 only costs slightly more than EL34 at $80/pair for 2A3. Why not just use 2A3?
SE EL34 Schematic - What do you think? Cassiel Tubes / Valves 7 16th December 2011 06:30 PM
EL34 SE triode mode A class sch wanted trancy Tubes / Valves 14 10th January 2008 10:16 AM
se 6c33c or se el34 schematic karma Tubes / Valves 10 2nd July 2005 05:40 PM
calculate +B in EL34 SE triode conect alejo Tubes / Valves 18 30th October 2004 09:32 PM
el34 se schematic opinion trancy Tubes / Valves 3 21st April 2004 03:52 PM
Copyright 1999-2017 diyAudio
