PCL86 se amplif. - diyAudio
Old 22nd January 2013, 07:40 AM   #1
romicap is offline romicap  Romania
romicap's Avatar
Default PCL86 se amplif.
http://i48.tinypic.com/qnjmvm.jpg
http://i45.tinypic.com/20b0klk.jpg
my first PCL86 amp!
http://i47.tinypic.com/2qnwm1j.jpg
http://i48.tinypic.com/2cekrxt.jpg
Old 22nd January 2013, 10:38 AM   #2
ilimzn is offline ilimzn  Croatia
The way your schematic is drawn, the NFB from the secondary of the output transformer does not work as the secondary is 'floating' - in order for it to work, the other end of the secondary winding should be connected to ground.
Old 22nd January 2013, 11:05 AM   #3
azazello's Avatar
resistor from second grid of ecl 86 must be connected to first wire of output transfomer.
Old 7th March 2013, 03:45 PM   #4
romicap's Avatar
New amp 6P6S and ECC82 driver - 4W 1%
http://www.elforum.ro/download/file.php?id=38907 and foto:
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
how to use PCL86 instead of ecl86 v4lve lover Tubes / Valves 3 8th December 2011 08:45 PM
Filament for the PCL86 boessenkool Tubes / Valves 2 25th January 2009 08:54 PM
Amplif mono with 4 x TDA 2030 dsasorin Chip Amps 8 26th September 2007 10:42 AM
sae x25a power amplif pengxy Solid State 0 29th April 2005 05:52 AM
Copyright 1999-2017 diyAudio
