The volume pot - The hidden villain of preamp - Page 8 - diyAudio
Old 27th January 2013, 11:04 PM   #71
SY's Avatar
Originally Posted by popilin View Post
The only reference to noise, I could find is
The Sound of Silence: Lowest-Noise Riaa Phono-Amps: Designer's Guide - Burkhard Vogel - Google Libros
Which gives us for the ECC82, on a 20KHz bandwith, something like Vn ≈ 6.4μV RMS, well below the estimate of post#16.
Vogel's treatment of noise is quite good.
FWIW, Mullard's measurements of EF86 at 1.25mA anode current are about 2uV over 25Hz-10kHz (equivalent to 2.8uV over 25-20k). That's quite quiet for a pentode! As MJ points out, this is still somewhat higher than the RF-based equations predict, but still the same order of magnitude. If I remember correctly, Vogel ended up with a triode ENR equation which was roughly double that of the RF equation, i.e., something like 5/gm.
As a practical matter, I don't ever use phono stages with 20k output impedances, and I've never found the noise from a 50-100k pot in a tube line amp to be an issue. If you're concerned about it, use a transformer volume control.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th January 2013, 11:48 PM   #72
popilin is offline popilin  Argentina
popilin's Avatar
Yes, right? I love it, unfortunately I can't read the whole thing, it's just a sample.
BTW. Morgan Jones third edition is one of my favorite books.
I have read that section several times, and predictions are astonishing.
I have seen something like 3/gm.
Taking as a reference to Allen Wright, and your His Master's Noise, I would never do that, just said that to support my point, but keep it quiet.
I don't get along great with transformers, is also out of my budget.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 27th January 2013, 11:56 PM   #73
kevinkr's Avatar
<snip>
As big fan of good transformers (my system typically has 4 in the path, and never less than 3 regardless of source) I do have to say a mediocre transformer will be worse than no transformer at all..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th January 2013, 12:26 AM   #74
popilin's Avatar
I agree with every word, and of memories to me left my last five transformers, more than 80 windings, handmade, during three months.
I hate transformers!
Old 28th January 2013, 10:34 AM   #75
ruffrecords's Avatar
For a full treatment of noise in tubes, including flicker noise, I would recommend chapter 8 of 'Amplifying Devices and Low Pass Amplifier Design' by E.M. Cherry and D.E. Hooper. Copies are expensive and hard to come by so I would recommend getting your local library to obtain a copy for you.
Cheers
Ian
Old 28th January 2013, 12:28 PM   #76
popilin's Avatar
Cheers
Ian
Hi Ian
The scope of our actions is often unexpected, maybe you never imagined that your posts and knowledge you helped me on the other side of the world, always with a clear and friendly style.
It is for this reason that you are among the superheroes of the forum, along with Wavebourn, SY, DF96, Salas and some other, who knows excuse my forgetfulness.
As well I have noted, noise is a rather complex issue, thank you very much for your advice.
Old 28th January 2013, 01:52 PM   #77
Hi Ian
Thank you for the kind words. It is really nice to know that your efforts are appreciated.
Unfortunately there is very little information on tube noise in the audio band and even less in data sheets. One of the few tube data sheets I have found that does have this information is the E83F. It's Req at RF is 1000 ohms max but in the audio band up to 10KHz it is 30K. OK it is a pentode so partition noise is a big contributor but the difference is 15dB. It's data sheet is here:
E83F @ The National Valve Museum
Cheers
Ian
Old 4th May 2014, 06:47 PM   #78
70 khz phono response is possible but the RIAA Eq in the preamp will all but kill any trace of it
Old 4th May 2014, 08:39 PM   #79
popilin's Avatar
Rise time is inversely proportional to bandwidth, so a phono cartridge which can go up to 70 KHz must be pretty fast. IMHO.
With a properly designed EQ adding the missing 3.18 s time constant, you can go easily to 10 Hz - 50 KHz ( 0.1 dB), so I don't see the problem.
Old 4th May 2014, 10:10 PM   #80
RIAA curves place the sensitivity of a flat cartridge at least 40db down at 20 khz from 20hz.
You are correct that in having a mechanical structure that can resolve 50khz is a very good thing.
When youdid the volume pot noise tests, Did you leave the amplifier input impedance at normal value or short the amplifier input to ground?
50K volume pot in place of a 20k volume pot? robgilmo Solid State 8 18th December 2012 12:34 AM
Need to Upgrade Tube Preamp Volume Pot MrKTrout Tubes / Valves 6 29th December 2011 04:01 AM
single push volume pot, volume up/down via a button. dragonxwas Analogue Source 4 2nd June 2011 07:56 PM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 06:07 AM
Effect of using 50k pot instead of 100k pot in tube preamp? KT Tubes / Valves 5 17th February 2006 10:56 PM
Copyright 1999-2017 diyAudio
