Old 25th January 2013, 09:28 AM   #51
DrRick is online now DrRick  United States
Ian,
I meant to post both. Thanks!
Originally Posted by ruffrecords View Post
I don't think I am THAT good but thanks for the kind words nonetheless.
People might also like my DIY site too:
http://www.ianbell.ukfsn.org/EzTubeMixer/
Cheers
Ian
Peace,
DrRick
Old 25th January 2013, 11:24 PM   #52
popilin is offline popilin  Argentina
popilin's Avatar
Hi Ian, hi DrRick, thanks for the links !
Now try to show that putting a pot on the input of a high gain amplifier, in this case a 100W class A hybrid, is not a very good idea.
Sim#1 - Amp without pot.
Sim#2 - Amp with 100K pot.
Sim#3 - Amp with 50K pot.
Sim#4 - Amp with 10K pot.
I do not suffer from insanity, I enjoy every minute of it. -Edgar Allan Poe
I hate idiots, that's why my house has no mirrors. -Just me ?
Old 26th January 2013, 02:22 AM   #53
It may surprise you, but I did read the whole thread. While I note there are some 50 posts, a mere handful relate to pots, and not a single one proposes how to control the output volume in the absence of a pot, or a switched attenuator.
Pots, or variable attenuators, are a necessary evil in any practical music reproduction system intended for use in a domestic environment. Many systems moreover, manage to have a pot without any audible noise. Even in those systems where there is audible noise, it is masked by the music in most circumstances, and noise is regarded by many as the most tolerable of flaws in a reproducing system.
So what's your point?
Old 26th January 2013, 03:55 AM   #54
popilin's Avatar
I can vouch for this.
What you say is correct, there are only a few posts referred specifically to the pot, some joke among friends, and as any exchange of ideas, several interesting issues arise.
In the world of the SS, the pot presents no difficulties, being low impedance devices, you can put very low pot values.
However, with valves, it gets more difficult, and the noise starts to be an issue.
We also discussed the effect on bandwidth and phase shift.
As you say, the pot is a necessary evil, my point is to put it where do the least damage.
Old 26th January 2013, 10:17 AM   #55
ruffrecords's Avatar
It is fairly obvious that a large value pot contributes more noise than a smaller value one. It is also fairly obvious that the noise contribution of a pot will be greater if you put more gain after it. So to answer your question it will create the least noise if it is last in the chain. So what you really need is a 100W constant impedance T pad connected between the 100W amp output and the loudspeakers. This may well affect the damping factor but that is a whole other debate.
What you really need to look at are ALL the noise sources in the system including the source material and compare their values relative to the pot at each proposed placement of the pot.
Something to consider: just about every professional mixer uses 10K faders so just about every source you feed through your pre-amp has been through at least one and probably several 10K pots. If you use a 10K pot at your pre-amp input, how is its noise contribution likely to compare with that of all the 10K pots that preceded it?
Cheers
Ian
Ian
Old 26th January 2013, 02:37 PM   #56
popilin's Avatar
It is fairly obvious to you, that you know a lot and have all the experience.
Besides my lack of knowledge, I think slowly, and nor with the equations in front of me I could see the problem.
Judging by the countless number of circuits that adopt the traditional scheme, even with 500K pot, probably I am not the only one.
When I noticed the problem, it was a revelation to me ! and I want to share it.
I believe that without deep bass, musical experience would be incomplete, and given the not very low output impedance of valve amps, I designed my hybrid.
Anything that reduces damping factor, is not a good deal, especially when you do not use global feedback.
That is precisely the idea, but as I said before, we have no control over the source material, for each format, analog or digital, it can vary greatly depending on the recording company, not just blame the recording engineer.
Cheers
Ian
Good point, but it gives me chills just thinking about it, is not a trivial issue, fortunately I do not need a mixer.
Another approach is to use transformer based attenuators, but the magnetic hysteresis curve is far from a straight line, and the use of exotic materials is far from my pocket.
Old 26th January 2013, 02:47 PM   #57
rdf is offline rdf  Canada
rdf's Avatar
The new Benchmark DAC2 uses 32 bit internals to keep volume control enitely in the diigtal domain. As they put it, "digital inputs never pass through an analog potentiometer."
Ears aren't microphones.
Old 26th January 2013, 03:38 PM   #58
Ruff Sez:
"So what you really need is a 100W constant impedance T pad connected between the 100W amp output and the loudspeakers. This may well affect the damping factor................."
Peace,
DrRick
Old 26th January 2013, 04:37 PM   #59
Fair enough, but I think calling the volume pot a 'villain' is a little premature.
And the point is there is a whole range of noise sources in the pre-amp that you can control and pot noise is just one of them. You need to examine and quantify the others before you brand the volume pot as the 'villain'.
Cheers
Ian
Ian
Old 26th January 2013, 04:46 PM   #60
Hmm. Not exactly news to anyone who has ever designed a radio receiver.
Perhaps a brief recap of Friis' noise equation might have got us to the point a little quicker.
Good point. Not the one the OP was making, I think, but a good point nevertheless. Shame you couldn't have made it at the beginning of the thread, then we might have short-circuited some 50-odd posts...
50K volume pot in place of a 20k volume pot? robgilmo Solid State 8 17th December 2012 11:34 PM
Need to Upgrade Tube Preamp Volume Pot MrKTrout Tubes / Valves 6 29th December 2011 03:01 AM
single push volume pot, volume up/down via a button. dragonxwas Analogue Source 4 2nd June 2011 06:56 PM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Effect of using 50k pot instead of 100k pot in tube preamp? KT Tubes / Valves 5 17th February 2006 09:56 PM
Copyright ©1999-2013 diyAudio
