diyAudio Sponsor
Old 17th November 2003, 06:50 AM   #1
Default Auricaps
Wondering if anyone has much experience with Auricaps? I have been testing them for some time and would like to get others experiences with them. Maybe ask a question or two as speaker crossover caps.
Thanks.
Old 17th November 2003, 08:15 AM   #2
AKSA is offline AKSA  Australia
Quite good - strong bass for their size.
Sound muddy until they have a decent DC bias across them. This is fine for the majority of tube circuits, of course.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 17th November 2003, 09:03 AM   #3
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
This reminds me that JBL uses batteries to bias the caps in their crossovers. Is this simple to do? If so, how? Would this make Auricaps better speaker caps?
Thanks, Mark
Old 17th November 2003, 03:56 PM   #4
diyAudio Senior Member
fdegrove's Avatar
Haven't had the chance to try them yet but they look as if they're made by the same company that made the Sidereal caps years ago.
It looks as if they carry the same PTFE insulated leadout wires as well.
Should be easy enough to do but I wonder how some SS amps would react with DC on their output.
Any filmcap I know sounds better when biased, I suppose it would help the Auricaps too as Hugh points out.
Frank
Old 17th November 2003, 06:36 PM   #5
Default Thanks guys
Yep, that is what I noticed when I put them in the crossover, a slightly fuzzy sound.
Also noticed one other difference. Handclapping wasn't as good as the Solens (although the openness is much better than the solens). The harmonic structure seemed off. I am guessing that handclapping may have a very broad harmonic spectrum, plus/or the lack of bias?? Other than that, they sounded wonderful.
Thanks guys.
Old 19th November 2003, 09:38 AM   #6
Mike C is offline Mike C  United Kingdom
I've found Auricaps to sound very good indeed in
valve equipment, but note that they do seem to take
a long time to run in.
But for speaker crossovers, I recall seeing about
Auricaps vs Ansars, where the Ansars were preferred. These are not expensive, and may be had
from Wilmslow Audio or Cricklewood Electronics,
both in the UK and on the web.
Old 19th November 2003, 03:38 PM   #7
Default Thanks Mike
Will check to see if there are dealers in the US.
Been running the auricaps all day, every day and tweeking the crossover slightly seems to be helping. The 1270s are really sounding great.
I may be to picky as I want absolute perfection.
Another thing. Depending on which order I play the selections, the sound is different. If I play a bass heavy song and the next selection is a female solo, the voice sounds lighter than if I play the female solo first. Anyone else run into that problem?
FS: (4) .01uf/600V Auricaps mrdon Swap Meet 11 13th October 2008 05:17 AM
Are these the right Auricaps for Trends amp? sdk Class D 2 2nd June 2008 08:27 PM
has anyone used auricaps and BG on their aleph 1.7? jarthel Pass Labs 10 29th December 2007 03:14 PM
Large value Auricaps Prune Parts 0 1st February 2004 05:09 AM
Anyone Tried Auricaps? AKSA Parts 44 23rd August 2002 05:33 AM
Page generated in 0.09051 seconds (79.76% PHP - 20.24% MySQL) with 10 queries
