#21 | |
Negative feedback is used in such cases because it makes the basic gain adjustment very simple, it reduces distortion remarkably, it gives better frequency response and gives lower output impedance. All these takes place without any objectively observable flaws. How would you design a simple voltage amplifying stage having gain 6 to 10 dB, distortion below 0.1 % (@ 10 Vrms) and constant output voltage with variable load between 22k to 220 k ? |
#22 |
I would consistently recommend either an Aikido or a FVP5 preamp, and I would adjust the overall gain by correct selection of the input valve. No need to resort to gNFB in a preamp to achieve excellent measured results.
This will forfil of the essential requirements of a preamp. I really don't want to get into another pointless long discussion about feedback other than saying - why invoke a distortion correction mechanism when a correct design has no significant distortion. Every valve has its function, but choosing a valve which is out of its functionally best zone of operation and then compensating for its inadequacy by apply gNFB seems like a very bad design approach. Shoog Last edited by Shoog; 22nd January 2013 at 06:42 AM. |
#23 |
Distortion is not the only issue. There are some other important too.
What valve(s) would you use for a pre amplifier with 6 to 10 dB gain and without NFB ? Last edited by artosalo; 22nd January 2013 at 06:48 AM. |
#24 |
I would point you to the official source on the Aikido if that gain is essential to you;
Aikido octal mono PCBs and 5687 PCBs and Aikido and 300B amplifiers There is a nice table for selecting a wide range of gains. I consider a low output impedance as more essential and the ability to drive high capacitance loads as critical. High current drive would be my main design choice. I personally used a 5687 into a PP transformer output with a significant step down to achieve what I need in a preamp. Shoog Last edited by Shoog; 22nd January 2013 at 06:55 AM. |
| New Schematic Linestage Tube Preamp using EF86 & 12AX7 | Edwind | Tubes / Valves | 47 | 24th January 2012 02:17 PM |
| Can anyone help with an ef86 tape preamp mod please? | myredbook | Tubes / Valves | 3 | 17th October 2011 09:37 PM |
| ECC82 based preamp | SSassen | Tubes / Valves | 81 | 2nd April 2011 06:05 AM |
| EF86 tube preamp | gaborbela | Tubes / Valves | 2 | 10th February 2010 07:00 PM |
| 6N1P or EF86 for bass guitar preamp? | Mikael Abdellah | Tubes / Valves | 14 | 10th March 2007 08:01 AM |
