ef86 based preamp
ef86 based preamp
Old 21st January 2013, 09:57 AM   #11
renjiish is offline renjiish  India
Try this, it is really good.
6th Street Bridge: Triode Connected EF86 linestage and headphone amplifier
Old 21st January 2013, 09:59 AM   #12
RE: EF86 Preamp - hagustos - Tube DIY Asylum
Old 21st January 2013, 10:00 AM   #13
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
I have used this one from Svetlana as a preamp in my headphone amplifier, and it works very well.
Regards Max
Old 21st January 2013, 10:01 AM   #14
DF96 is offline DF96  England
The author (of the preamp linked from post 11) admits that it has too much gain.
Old 21st January 2013, 11:52 AM   #15
kstagger is offline kstagger  United States
kstagger's Avatar
even triode connected, a voltage gain of 25 is terribly high with modern digital sources. Perhaps the additional gain would be nice for a HOMC. I would also suggest some *gasp* local and/or loop feedback to reduce the total gain.
Old 21st January 2013, 12:46 PM   #16
artosalo is offline artosalo  Finland
artosalo's Avatar
Triode connected EF86 has gain comparable to any medium mu triode and thus can be used easily with some NFB, which improves the linearity as well.
Old 21st January 2013, 01:15 PM   #17
Shoog is offline Shoog
Shoog's Avatar
It is possible to achieve vanishingly small distortion in a preamp stage without any negative feedback - so why would you use it.
Any of the more appropriate line amp tubes such as the ECC99 or 5687 can deliver orders of magnitude more current drive which will address far more problems than using a weedy EF86.
Shoog
Old 21st January 2013, 01:53 PM   #18
enzoastro is offline enzoastro  United Kingdom
Plenty of quad 11 owners would, i'm sure, be happy to jelp you dispose of a few nos ef86.... :-)
Old 21st January 2013, 04:47 PM   #19
intensate is offline intensate  United Kingdom
intensate's Avatar
Thanks everyone,you have all given me some great advice.I just wanted to use ef86 as they are mullards and new. I may need to get some ecc83 from russia or china then as I have used my stock up!
Any one recommend new ones that are mullard like?
Old 21st January 2013, 08:44 PM   #20
multi is offline multi  Australia
The EF86 and E80f are excellent for pre-amps wired as triodes as they have low micro-phonics.
Phil
ef86 based preampHide this!Advertise here!
New Schematic Linestage Tube Preamp using EF86 & 12AX7 Edwind Tubes / Valves 47 24th January 2012 02:17 PM
Can anyone help with an ef86 tape preamp mod please? myredbook Tubes / Valves 3 17th October 2011 09:37 PM
ECC82 based preamp SSassen Tubes / Valves 81 2nd April 2011 06:05 AM
EF86 tube preamp gaborbela Tubes / Valves 2 10th February 2010 07:00 PM
6N1P or EF86 for bass guitar preamp? Mikael Abdellah Instruments and Amps 14 10th March 2007 08:01 AM
