diyAudio Sponsor
Old 17th November 2003, 01:38 AM   #1
AKSA is offline AKSA  Australia
Default SE 6EM7 amp
Does anyone here have any experience of a 6EM7 SE amp?
My concern is hum......
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 17th November 2003, 01:39 AM   #2
li_gangyi's Avatar
yeah...but I used a 13EM7...absoulte no hum...but not very high power either...I think it's myoutput trafo...but it doesn't really do good bass...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 17th November 2003, 01:43 AM   #3
diyAudio Senior Member
fdegrove's Avatar
Why?
Is this a SE or PP circuit?
Frank
Old 17th November 2003, 01:49 AM   #4
li_gangyi's Avatar
he said SE...so I guess it would be pretty close to Fred's MiniBlok thingy...dirt cheap set I recall...
Old 17th November 2003, 02:01 AM   #5
fdegrove's Avatar
So? What's the problem with the 6EM7 SE or PP for that matter.
I don't see any in particular...
And WTF is Fred's Miniblok thingy anyways???
Frank
Old 17th November 2003, 02:23 AM   #6
li_gangyi's Avatar
ok...some of us here might know Fred...he regular posts on the newsgroup rec.audio.tubes.
his miniblok design can be seen here.http://dogstar.dantimax.dk/tubestuf/miniblok.htm
Old 17th November 2003, 08:51 AM   #7
Thanks guys,
Fred's amp is VERY interesting; it is, in fact, a 6EM7 with a 13Vac filament, but still indirectly heated, and certainly highly relevant.
Nicely designed, very well explained by Fred. The analysis of the harmonic structure is very illuminating. Fred makes the point that you can certainly tell it's colored, but that somehow the SET enhances the soundstage and the gutsy transients of orchestras. That's good enough for me..... And it's so simple it could be ultimately built out to drive my Svetlana 811-3s for a little more power! (or a tacked-on push pull SS output stage!)
This looks like a very simple way to get into the SET sound, and Fred's circuit uses commonly available parts at very low cost. It's probably five times cheaper than building a 300B or 211 amp, and for the 1.3 watts it produces, probably enough for a workshop environment OR headphones.
Thanks all, this is a wonderful research forum!
Hugh
www.aksaonline.com
Old 17th November 2003, 01:09 PM   #8
li_gangyi's Avatar
yeah...and it's got cheapie power transformers as well....
Next project 6EM7 mashaffer Tubes / Valves 31 28th September 2008 05:13 AM
6EM7 Amp jaymanaa Tubes / Valves 12 24th July 2008 04:01 AM
first post, PS for 6em7 SET amp spgjmf Tubes / Valves 4 20th March 2008 08:36 AM
yet another 6em7 amp rman Tubes / Valves 6 17th October 2007 02:26 PM
Page generated in 0.09822 seconds (77.83% PHP - 22.17% MySQL) with 10 queries
