#11 |
OK, I was wrong about the TF phase thought it would be like on schematics but mine is not, ie; positive feedback is edgy...anyway I got to try out Cathode FB after a bit of soldering and it did tighten up bass a little but the sacrafice of everything else is defintily not worth it, it was appearant right away, similar to GNFB but not to smear as much. I'm finding SET bass to be kinda relaxing, it's still large and defined but just doesn't have great impact.
BTW 4ohm tap did sound better. Thanks for the help so far. |
#12 |
phase correcting @output stage applied with a smar t way!and how Tango x'former made in such。
#13 | |
In my opinion, dumping factor of tube amp should be 1.0 at least. My OPT has 36 ohm of 3rd winding coil which adapted to 838(Mu of 50) and gets dumping factor of 1.6 with only CFB. If you don`t want using GNFB, you should use full of your 2nd winding, 16 ohm tap. May be you can get nearly 1.o of DF? I learned that even CFB with OPT, too much amount of NFB is affects to the sound (too tight). I have tried attached cathode feedback on my 811A SE amp. An 811A has so high Mu(160) that 36 ohm of 3rd winding seems too much. With out CFB, dumping factor was 0.2 and with 36 ohm of CFB DF become 2.0. Schematic 14 shows added 50 ohm of resister in between cathode and 3rd winding coil, functioning current feedback and reduced dumping factor from 2.0 to 1.5. Schematic 15 shows using 4 ohm of 2nd winding coil and added small amount of GNFB and get total DF of 1.0. |
| How the negative feedback really works and an alternative feedback question | Amit_112dB | Solid State | 35 | 4th February 2013 02:16 PM |
| global negative feedback schematic | sdinfo | Tubes / Valves | 160 | 26th August 2010 07:16 PM |
| F4: Schematic and Feedback Circuit | Kashmire | Pass Labs | 1 | 29th November 2009 04:25 AM |
| Original schematic without feedback | Kostya-M | Solid State | 16 | 16th April 2008 07:48 PM |
| 805 + 300b Amplifier Schematic | Pyre | Tubes / Valves | 0 | 28th February 2007 11:56 PM |
