#11 |
Moi, grumpy? No, I am amused. Several of us have tried to explain why it is a bad idea, yet you seem unconvinced. If you don't welcome comments, why post your idea?
#12 | |
Loren 42,
Since when can you get NFB with a resistor from anode to cathode? That makes PFB in my book! Quote:
#13 |
I notice that there is an opamp in the circuit? Yikes!
#14 | |
So why not try again. |
#15 |
Hmmm Interesting! It may be advertised as "Opamp Distortion Compensator". Or "Anti-Distorter" :-)
Edit: add "Anti-Triode" here and call it "Straight Wire Amplifier" :-)
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#16 | |
#17 |
#18 |
OK, thanks. "Better than ideal" - so it will improve the music, correct for studio errors etc., just like some high-end gear?
#19 |
Jokes aside.
Nothing is wrong with this topology. With -1 gain opamps work pretty nice, so why not to use such a buffer to add feedback to the single tube stage? However, opamp saturation will cause quite nasty distortions, high peaks instead of flatter tops.
#20 |
DF96, for someone with internet access you have a refreshingly innocent idea of "perverse" !
As Wavebourn points out, "with -1 gain opamps work pretty nice". None of the naysayers are actually coming up with noise figures for this topology versus another that offers high z-in using a single valve, perhaps they might care to do so? Quantification before condemnation might be sensible. As for distortion, it comes in two flavours, the sound the user likes and the one he doesn't. This doesn't in any case look like it's going to suffer overly from noise or distortion, given a sane implementation, so to dismiss it as 'pointless' seems both arrogant and rude to me - a shame to see that attitude from a moderator, SY. On a practical note, it might be worth protecting the inputs of the op-amp from their max differential voltage being exceeded as C2 charges at switch on.
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds. |
| Partial feedback (anode grid) with cathode follower | swordsman | Tubes / Valves | 6 | 9th July 2011 06:29 AM |
| Wanted: Zero feedback 2-10x gain line stage...prefer symmetrical | Ric Schultz | Analog Line Level | 14 | 26th February 2011 07:26 PM |
| Neg-Feedback into Grid of gain stage instead of cathode? | Alastair E | Tubes / Valves | 3 | 25th January 2011 10:19 AM |
| IV single stage inverting Feedback Amp | ccschua | Tubes / Valves | 18 | 6th July 2009 01:09 PM |
| Single FET line stage | wleediy | Solid State | 12 | 6th July 2004 06:18 AM |
