#11 |
What is dynamic resistance @ op point of an ultrabrightmblue LED?
#12 |
On the subject of using diodes in the cathode circuit, personally I quite like SIC Schottky diodes rather than LEDs, but has anybody tried vacuum diodes?
see: http://www.chimeralabs.com/images/axiom.sch.jpg Could be fun
#13 |
See Morgan Jones' Valve amp book. Red LEDs are the way to go, if you want LED bias, their AC impedance is the lowest.
Filament bias seems a good alternative. I use fixed battery bias.
Take the Speaker Voltage Test! |
#14 | |
Generally I prefer battery grid bias over diodes in the cathode anyway, but my interest is whether anybody has tried vacuum diodes, as I thought it could be entertaining. Cheers |
#15 | |
работник
Very interesting 300b design and here..... Comparison of Diode Biasing with other methods |
#16 | |
Many thanks for that. Simon |
#17 | |
#18 | |
BTW, they sound great in a preamp as well! Excellent bass, clear treble. |
#19 | |
#20 | |
| What is the theoretical advantage of direct heated triodes? | cotdt | Tubes / Valves | 205 | 5th February 2013 09:13 AM |
| 1AG4 Direct Heated Pentode, Output | TheGimp | Tubes / Valves | 11 | 18th February 2012 09:19 PM |
| Best low-signal direct heated triodes? | gentlevoice | Tubes / Valves | 7 | 5th May 2008 03:03 AM |
| Direct heated tubes with centre tap on filament | mig-ru | Tubes / Valves | 2 | 13th May 2003 01:44 AM |
