Wiring up 3 6.3 Volt Heaters to a 12V supply - Page 2 - diyAudio
Old 18th January 2013, 03:00 PM   #11
KatieandDad's Avatar
Just look at the schematic and look at the relative voltages of the cathodes with each other.
I'm scare mongering a bit, it's unlikely but it's worth looking into especially when some designs have heaters lifted above 0V.
Old 18th January 2013, 03:24 PM   #12
akimmet is offline akimmet  United States
Each 6bq7a uses 400mA each. That is 1.2A total. Lets not for get the inrush current involved with cold tubes, I don't doubt each tube's current draw would exceed 1A when cold.
A LM317 can barely handle 1.5A in absolutely prefect conditions. In practice I only trust them up to 1A. I would recommend if you wish to go this route, you have a voltage regulator for each tube. Each voltage regulator would in turn need a fairly large heat sink.
Old 18th January 2013, 03:52 PM   #13
palmas is offline palmas  Portugal
Use 3 317 or use one TL1083
Old 18th January 2013, 04:49 PM   #14
Vincent77's Avatar
Or a LM350. Or just buy the module I mentioned. It's cheap, already assembled and needs no heatsink!
Old 18th January 2013, 05:05 PM   #15
You could use one of these. Tube Filament Regulated Supply Soft Start Kit | eBay
Old 18th January 2013, 05:41 PM   #16
Originally Posted by supersonik319 View Post
Each heater takes 0.4 amps, so at 12 volts, I should use a 30 Ohm, 5Watt resistor, just to confirm:
+12V ---^--^--- GND
+12V ---R--^-- GND
Am I missing something? At 12 - 6.3 = 5.7V drop across the resistor and 0.4A current, I get 14.25 ohms (and 2.28 W)
Old 18th January 2013, 08:16 PM   #17
Why not keep it simple. Fit a 15 ohm resistor in series with each heater. Bridge each resistor with a higher value to get 6.3v on each heater. This way, the cold inrush current is limited as well.
Old 18th January 2013, 08:49 PM   #18
DF96 is offline DF96  England
And you waste about 7W, instead of 2.4W by doing it properly.
Heaters wiring help! cjkpkg Tubes / Valves 19 5th October 2010 07:23 PM
Briefly subjected heaters to about 12v by accident. bigwill Tubes / Valves 6 20th July 2008 11:38 PM
AC wiring heaters, A or B ? zigzagflux Tubes / Valves 10 4th July 2008 09:43 PM
PSU for 12V DC heaters cbutterworth Tubes / Valves 15 9th March 2007 06:25 AM
Series wiring for heaters XZur Tubes / Valves 5 19th December 2005 02:43 AM
Copyright 1999-2017 diyAudio
