| diyAudio Sponsor | ||
Hi guys
Just wondering have you ever make this Amp.... http://www.diyparadise.com/simpleel84.html I just wondering how it sounds...??
Mas Penk |
#2 | |
Alternatively, you could use a paraphase splitter like the Magnavox console amps. This can also sound very good, and doesn't require the CCS. Also, the amp you linked is wired in UL, it's output impedance will be quite high which may create some frequency response errors |
#3 |
Why not use another ECC99 and have a gain stage into a concertina? The ECC99 is both a great gain stage - low anode impedence so you can have an unbypasased cathode resistor - and a great tube for a concertina. I don't have a circuit, but you could start with 22k anode resistor on the first valve and 22k on top and bottom of the concertina, and adjust the cathode resistor of the input tube to suit your needs. I'm about to try this very thing when I get some time. At the moment I'm using a 6EW7 - second section first, into the first section as a concertina. Sounds pretty nice, and very simple.
#4 | |
#5 |
If i use EL84 as Driver will it sound better?
Because that site the author said that the amp will be more natural and live if we drive with EL84. It looks like he follows the Sakuma Amp which has implement "like drive like". Meaning if we like the sound of EL84 then use EL 84 to Drive EL84... btw does anyone has schematic for Good & Simple EL84... ? Does magnavox amp use same OP spec like i have 8K PP with UL 40%? thanks
Mas Penk |
#6 | |
diyAudio Senior Member
I feel every tubelover owes it to himself to study phasesplitters and balanced circuits indepth... Understanding AC behaviour versus DC behaviour does help alot, as does static versus dynamic behaviour.... Greetz to OZ,
Frank |
#7 | |
Frank |
#8 | |||
In the case with the EL84, you only need about 20V to drive the grids however you run them, and an ECC99 is more than up to the task. The ECC99 also hav less than half the input capacitance so it's easier for the previous stage to drive too (vi a vis the EL84 as a driver). Quote:
I'm not really fond of UL, preferring pentode esp if using NFB. The Magnavox I mentioned is pentode with NFB. Another simple design is the Acro or Dyna designs posted below. I'd use a 6SL7 in preference to the 12AX7 though. |
#9 |
The Acro
#10 | |
Can only saw I agree. One pet hate of mine is the term phase-splitter, because it's not a splitter, but an inverter, and then you get all these idiotic posts from the cult of the SET types who think that it cuts the signal in half. Cheers Brett |
| Simple EL84 amp... | Skorpio | Tubes / Valves | 11 | 3rd January 2009 09:25 PM |
| 12AT7 and the Simple EL84 | haziz | Tubes / Valves | 75 | 11th September 2007 11:32 PM |
| Yeo's Simple EL84 with a twist | sorenj07 | Tubes / Valves | 19 | 18th October 2006 10:48 PM |
| newb needs help on simple el84 amp PS | DJNUBZ | Tubes / Valves | 28 | 16th December 2005 06:47 PM |
| anyone tried the diy paradise simple el84 pp | RockysDad | Tubes / Valves | 6 | 11th April 2005 05:19 AM |
| Page generated in 0.11598 seconds (81.96% PHP - 18.04% MySQL) with 11 queries |
