diyAudio Sponsor
Old 17th November 2003, 01:42 PM   #21
HDTVman is offline HDTVman  United States
[QUOTE]Originally posted by andyjevans
[B]The one you refer to (dynaco Low Powered) has a 100R cathode R which is in common for both triodes and is decoupled with a 100µF cap.>>
I see 100R between the cathode 1 and cathode 2, with cathode 2 taken to ground through the 100uF cap, so where's the bias resistor for the second section, and in any case wouldn't we expect round 1K?
The DC bias path is via the 1K feedback resistor and the secondary winding of the output transformer to ground.
Can you see it now?
Later BZ
What ever makes the tunes flow
Old 17th November 2003, 02:29 PM   #22
Can you see it now? Later BZ
Hmmm. I've never seen this arrangement - I just assumed that the 1K was the feedback resistor. Haven't seen this anywhere else.
Apropos the concertina in Dyna-based EL84 amp above, why 27k and 33k? I've only seen equal resistors in concertinas? What's the intention? Cheers, Andy
Old 17th November 2003, 04:42 PM   #23
While we're on 'puzzled of UK' why does the concertina in the previous schematic have unequal resistors - first time I've seen that. What's the idea?
Old 18th November 2003, 04:35 PM   #24
[i]
Can you see it now?
[/B]
The DC path for both triode sections is common to the 1K resistor and the transformer. The 100 ohm resistor is just in series with it to provide some AC decoupling for the cathode of triode #2 with the cap to ground. This also give a different amount of feedback to the two triode sections.
This type of feedback circuit is very common with equipment that is as old as I am. Back in the old days designers made an effort to get the most out of the circuit without adding more parts but by making what was there multitask a bit.
Later BZ
Old 17th August 2006, 01:23 AM   #25
Default Re: Simple EL84
Originally posted by Mas Penk
Hi guys
Just wondering have you ever make this Amp....
http://www.diyparadise.com/simpleel84.html
I just wondering how it sounds...??
Just looking at some old threads
By not using a seperate phase spliiter like the above example, will the power be lower that with? I seem to recall reading somewhere that it does, though I can't remember where or how...
Old 17th August 2006, 01:55 AM   #26
Yes the power will be less.
The EL84s are being run as a diff amp and so are their own phase splitter... err.!! that should be phase inverter. I have never tried this BUT I expect it to have a fair amount of 2nd harmonic distortion due to imbalance in the output stage.
The reduced power is due to it being strictly Class A - Not sure what its clipping behaviouir would be like but don't expect it to be great.
Ian
Simple EL84 amp... Skorpio Tubes / Valves 11 3rd January 2009 08:25 PM
12AT7 and the Simple EL84 haziz Tubes / Valves 75 11th September 2007 10:32 PM
Yeo's Simple EL84 with a twist sorenj07 Tubes / Valves 19 18th October 2006 09:48 PM
newb needs help on simple el84 amp PS DJNUBZ Tubes / Valves 28 16th December 2005 05:47 PM
anyone tried the diy paradise simple el84 pp RockysDad Tubes / Valves 6 11th April 2005 04:19 AM
Page generated in 0.08619 seconds (76.89% PHP - 23.11% MySQL) with 11 queries
