Today one of the tubes in my amp failed, didn't see it coming, no flashes, no smoke, buzz, hiss, just died quietly. Upon inspecting it closely I see the cloudiness on the glass envelope that looks like the result of getters spewing beams of electrons. There are also cracks in the glass base, where the connecting wires go from the glass envelope to the pins. Could it be that cracks in the glass compromised the vacuum in the tube causing it to fail? The mesh plate looks spotless - no browning, discoloration or deformations. I don't have a tester that could test 300B.
When in the circuit the filaments were not glowing, there are no shorts between filaments and anode/cathode, and filament itself seems to be conducting (according to my DMM). Replacement tube seems to be working fine, heater voltage measured 5VDC exact. What would cause a tube failure like this? Could it be manufacturing defect? The tube in question is not exactly cheap and has good reputation. |
#2 |
expert in tautology
Looking at ur nice well focused pix, I can't clearly see a stress crack through the base envelope, to the outside air. If it is there, even a micro path, that would kill the tube asap.
Looks like there has been stress cracking in two places? I'd say this is a defect, but if the tube has many hours on it, I doubt the mfr will make good, no harm in asking, and sending along the pix. If the tube shows no resting current and the filament lights properly, then it is definitely not conducting. Since the replacement tube does work, it's a pretty safe assumption that it has failed, and likely that those cracks are the cause. Do your other equal or similar hour tubes show any sign of cracking?
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#3 | |
I will send the tube to Mr. Wugang for them to review it. Knowing their reputation (Sophia) I would expect them to come up with something. Tube manufacture date is 12/16/2011. Last edited by ClefChef; 16th January 2013 at 07:26 PM. |
#4 |
The cloudiness around the getter on the glass indicates air has entered the tube. .
#5 |
I called Sophia and was surprised to get Richard Dwu himself on the phone. I explained the matter to him and he asked me to send the pair back for them to look at. I would not expect them to replace the failed tube for free, maybe a discount on a matching tube to make a pair...
In regard to the cracks - in picture nr. 2 the crack is clearly visible. It is formed along the wire that runs from the base of the tube to the inside of the glass envelope and is baked into the inside of the glass pillar. There is a second, smaller crack that doesn't seem to run all the way. |
#6 |
It is clear that the vacuum got compromised from the crack. The glass was not tempered properly on this one. I have the same tubes and they are reliable so far.
#7 |
Nice pictures, btw.
#8 |
Easily could have been from shipping stress.
_____________
#9 |
I agree. If this tube used the thick glass as 6C33 and GM70 this fail not happen.
Military tubes has many advantages...
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average. |
#10 |
Sophia 300b uses thick glass, much thicker than EH or ShuGuang. These tubes were "sitting" in my amp for quite a while before one of them quietly died. I am inclined to think that cracks developed from heating/cooling process of normal tube operation. shipping stress would manifest right after the shipping.
| HeathKit Euw-15 Tube power Supply failure. | harkkam | Tubes / Valves | 3 | 6th January 2011 11:51 PM |
| 300b tube cage | dsavitsk | Tubes / Valves | 15 | 23rd January 2010 10:29 PM |
| Tube rolling causes failure... | Zap | Tubes / Valves | 10 | 3rd August 2008 03:04 AM |
| Tube Failure | jwatts | Tubes / Valves | 11 | 12th February 2005 06:54 AM |
| Tube failure | Christopher | Tubes / Valves | 47 | 30th May 2003 03:35 AM |
