diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   how to see if a Mullard 12ax7 reissue is long or short plate (http://www.diyaudio.com/forums/tubes-valves/227965-mullard-12ax7-reissue-short-plate.html)
Mr. Green 16th January 2013 04:36 PM
Can anybody help me out how to see if my re-issue mullards are long or short plate ? How do can you tell the differnce? Any special markings ?
kevinkr 16th January 2013 04:55 PM
The length of the plates themselves, there should be plenty of photographic examples online to allow you to verify this.
Salectric 16th January 2013 05:03 PM
Take a look at the Mullard photos on the Tubeworld.com website. They clearly show the difference between long and short plates.
TubeHead Johnny 17th January 2013 04:38 AM
The reissue (Russian) Mullard 12AX7 is the exact same tube as the Sovtek 12AX7LPS, which are both long plate, with a spiral filament.
Mr. Green 17th January 2013 06:17 AM
Thank you fro your replies, they where very helpful.
I found out they are long plates, and can now tell the difference. Thanks
Resources saved on this page: MySQL 18.75%
