Long Preamp to Power Amp Cable Lengths
Old 16th January 2013, 03:54 PM   #11
Loren42 is offline Loren42  United States
Originally Posted by palmas View Post
I could not find if you tryed already the normal long SE cable solution and found a problem?
Yes. Hum from a ground loop. The cable ground is also disconnected at the power amp.
I am looking for a long term robust solution.
Old 16th January 2013, 04:53 PM   #12
palmas is offline palmas  Portugal
I had some similar problem from the phono amp to preamp (4m in single-ended).
Had a pair of Lundahl LL1592 and some balanced cables laying around, and as my pre has balanced input...
hum and noise disapeared and sound is great. So great I'm thinking of getting some more of these trafos for balanced to SE input on the amps
Hope this helps
Old 16th January 2013, 05:22 PM   #13
Antoinel is offline Antoinel  United States
If the output stage of the preamp is a current source [high Zo] instead of a voltage source [Zo ~ 0], will it help resolve this problem. Is it Krell which uses this non-standard approach?
Old 17th January 2013, 12:58 AM   #14
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
You have two options for the ground loop, to break the "galvanic path" of the safety grounds plus signal grounds, or to shorten the ground loop.
The first option requires transformers, which are great if properly applied, but don't like high impedances and especially along with high external capacitances.
The second option is to shorten the ground loop by bringing AC line power along with signal from the source end. A simple DIY and "code" solution exists:
Amazon.com: Datacomm 50-3323-WH-KIT Flat Panel TV Cable Organizer Kit with Power Solution - White: Electronics
All good fortune,
Chris
Old 17th January 2013, 01:07 AM   #15
Thanks. That is an interesting product.
Old 17th January 2013, 02:30 AM   #16
Speedskater is offline Speedskater  United States
Speedskater's Avatar
I would reconnect all the safety grounds.
Connect all the components to one AC power strip (with a long extension cord to the amp).
Connect the RCA chassis jacks directly to their chassis's.
Use the above " LC-1 Blue Jeans cable "
Kevin
Old 17th January 2013, 07:28 PM   #17
Called Jensen transformers and they recommended simply using one CI-2RR Iso-Max transformer at the power amp.
Old 18th January 2013, 04:29 PM   #18
Eli Duttman is offline Eli Duttman  United States
Loren42,
I've done some thinking about your long cable issue. Blue Jeans, IIRC, uses a simple coaxial construction, which is not suited to the task at hand. Shielded "twinax" in a differential, if not true balanced, configuration seems correct. That length of shield, when carrying signal, can all too easily pick up noise. The shield should not carry signal and only be connected to the upstream end chassis, not signal, ground.
You previously mentioned wall plates. 2X Neutrik 203Ms will do the job for you. Online Components carries the Neutrik plates.
No ifs, buts, or maybes, you will have to buffer the PAS preamp. I'm giving the buffer some thought. More about that to to follow soon. However, this much is clear. You will need trafos to break ground loops up. Jensen can be pricey. CineMag offers competetive products, at lower cost. CineMag's CMOB-2L looks like a candidate for your situation. A DC blocking cap. is needed between the buffering voltage follower and the trafo. Contact CineMag for assistance in sizing that part.
Eli D.
Old 18th January 2013, 04:52 PM   #19
jcx is offline jcx  United States
heavy shield coax works fine in many instances
Mogami with good Belden coax can be excellent
really cheap RCA cables may only have a dozen or so spiral wrapped strands with <50% coverage, pigtail termination - they suck
Old 18th January 2013, 05:06 PM   #20
Originally Posted by Eli Duttman View Post
Loren42,
Eli,
Thank you for the information. Would a Jensen CI-2RR work as the isolation transformer if I can get it at a competitive price?
Long term I would like to roll my own preamp, but in the interim, does it make sense to upgrade the PAS 3 with one of those Tubes4HiFi PC boards?
I would like to retain the tone controls, so I was considering the TCLA here:
Dynaco PAS3 upgrades & modifications & parts
Unfortunately, I can't find a schematic nor a specification for the output impedance (uses a 12AX7), so I have no idea if it would be a solution or a waste of money. Your thoughts?
If I understand your wiring scheme, you would use a high quality shielded twin lead cable. Connect the two inner leads to the preamp out hot and ground. Do not connect the shield at the preamp end.
The other end goes to the isolation transformer where the shield is connected to the isolation transformer box, the hot to hot, and the other lead to the return side of the transformer.
The cable from the transformer box would connect that shield to the amp chassis, while the output of the transformer connects to the input of the power amp.
Long Preamp to Power Amp Cable LengthsHide this!Advertise here!
best arrangement to cut down cable lengths PreSapian Parts 31 13th March 2012 01:36 PM
Bulk Power Cable recommendation for long run Beez Parts 2 9th February 2010 05:38 PM
DIY X1 Preamp Power Cable? CptTripps Pass Labs 2 31st October 2003 02:20 AM
Speaker Cable Lengths? FrankRoss Everything Else 5 15th December 2001 02:46 AM
Copyright ©1999-2017 diyAudio
