Long Preamp to Power Amp Cable Lengths - Page 6 - diyAudio
Old 21st January 2013, 08:39 PM   #51
Loren42 is offline Loren42  United States
Originally Posted by smbrown View Post
Okay, just be prepared for a "milk down" at some point... :-)
Too funny!
Yeah, so far it has been running without fail for a few years now.
Old 21st January 2013, 11:00 PM   #52
I am confused. Are you saying the FET B+ should be ≤ 135 VDC?
No, the FET buffer needs not less than 135 VDC. Getting 160 V. with a cap. I/P filter from SS bridge rectified "120" VAC is easy. However, if you regulate the rail, some drop has to occur.
As the other posters have indicated, the PSU in the PAS can't support more than that circuitry already present. For Pete's sake, Mouser charges all of $11.20 for a Triad N-68X. Being frugal is good. Being cheap to the point of "shooting yourself in the foot" is bad.
Eli D.
Old 22nd January 2013, 01:10 AM   #53
Hey, I just noticed I have a PS transformer rated a 325-0-325 VAC & 12 VAC @ 2.5 Amps sitting in a drawer.
I don't know the current for the HV secondaries, but it has to be more than the PAS transformer as the transformer is bigger than the stock PAS.
Does anyone know if this transformer suitable for a replacement for the stock unit?
If so, it might also be a source for the 160 VDC for the FET.
Old 22nd January 2013, 02:07 AM   #54
smbrown is offline smbrown  United States
smbrown's Avatar
WAY too high on secondary voltage for the design being proposed. You could use a choke input filter to improve current but then you have to stick a choke in there. Just get an appropriate tfr.
best arrangement to cut down cable lengths PreSapian Parts 31 13th March 2012 12:36 PM
Bulk Power Cable recommendation for long run Beez Parts 2 9th February 2010 04:38 PM
DIY X1 Preamp Power Cable? CptTripps Pass Labs 2 31st October 2003 01:20 AM
Speaker Cable Lengths? FrankRoss Everything Else 5 15th December 2001 01:46 AM
Copyright 1999-2017 diyAudio
