TooB NooB: Options?
TooB NooB: Options?
Old 17th January 2013, 08:12 PM   #11
cogitech is offline cogitech  Canada
cogitech's Avatar
Originally Posted by GoatGuy View Post
Build it!
There's very little more satisfying early-in-the-game than just building something that has a great reputation, that doesn't cost too much, and that has a list of parts'n'pieces that you can actually find, acquire, stockpile, and eventually use to make the device.
I can imagine the satisfaction!
Further, if you "like it", one of the easiest things in the world later on will be to use the small amp as a driver for a much bigger one. The small amp would then be considered the ultimate "headphone amp". The "much bigger one" need not be very complicated at all it turns out.
I don't own a set of headphones and cannot imagine a reason to.
So long as your output transformer has a center tap on its secondary (a nice thing to have), or split secondaries (8+8 = 16, 8 = 8, 8|8 = 4 ohms), then it can trivially be hooked up to a 4-some of 6550s or EL34s in a separate enclosure, 1/3 biased in push-pull mode, with a separate high-voltage supply and output transformer. Easy to bump up, actually. Could use 8 tubes as well, 2 in parallel for both halves of the left+right channel amplifiers. With no trouble at all, you'd be pumping out 75 watts per channel of sweet tube goodness.
[eyes glazed over] Uuuuhhhh.....
Ah, tubes... noobs 'n' toobs are just a great mix.
WATCH OUT for the high voltages though. When we "old timers" say they can be lethal ... trust ... lethal means DEATH. DEATH without appeal to the reset-button, to try it again. DEAD. So, please ... go in to this with open eyes and GREAT high-voltage fiddling skilz.
Old GoatGuy
Yep. Not doing it. Sorry, but risking my life for something I "might like" is not my cup of tea. Going to buy a Musical Paradise MP-301 or something.
Old 17th January 2013, 08:14 PM   #12
cogitech's Avatar
Originally Posted by kstagger View Post
That's why I originally suggested an old Magnavox amplifier. They may look cruddy, but at least they are cheap and easy to fix. For a few $$$ it would be easy to recap one.
Kevin
Indeed, if one knew how to re-cap an amp (safely).
Sorry guys, but I know my limits. My family needs me around more than I need to build (or re-build) a tube amp.
Old 17th January 2013, 08:16 PM   #13
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
It won't have enough power for your microtowers, plus it's bandwidth compromised. You will need at least 12watts/ch, push pull EL84 would be a great place to start.
jeff
Old 17th January 2013, 08:19 PM   #14
cogitech's Avatar
jeff
Then I am out of luck.
SS for me.
Old 17th January 2013, 08:22 PM   #15
tomchr is offline tomchr  Canada
tomchr's Avatar
The Tubelab SSE is a solid design. My 6LU8 Spud was heavily inspired by the design, actually. You don't have to spend megabucks to build the SSE. With Edcor CXSE OPTs and a power transformer from Antek, you can probably build a complete amp for $250-$300 - not counting a chassis.
My current 300B amp sits on a piece of plywood. Hence, I call it the DeathTrap. It's a great way to test an amp design - assuming you can keep kids, pets, and other curious fingers away from it. You could build something similar for the SSE. See if you like it before committing to spending time, money on a chassis.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 17th January 2013, 08:48 PM   #16
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
You can buy a push-pull EL84 on eBay from China for $200, and switch out the coupling capacitors. It is cheaper than the cost of parts. I was planning to rewire the circuit but when i opened the amp, I was surprised that they used a classic push-pull circuit and the correct resistor values. There was simply nothing to mod except the coupling capacitors. It sounded amazing with American NOS tubes, almost as good as my own SET amps (transformers alone costed $600). The Chinese have really improved their circuits lately.
If you want power and don't mind Class D, they sell 1500W PA amps for $135 shipped. They do hiss, and sound somewhat cold and analytical, but sound great with a tube preamp.
Old 17th January 2013, 09:01 PM   #17
vinylkid58's Avatar
SS for me.
You'd be fine with a low power SE amp if you only listen at lower levels in an average size room, and don't require "any" headroom for loud music passages etc. I'm assuming your room size is above average?
jeff
Old 17th January 2013, 09:07 PM   #18
cogitech's Avatar
A $200 EL84 PP is something I would consider. Any links, e-bay or otherwise, that I should check out?
What about: http://www.ebay.ca/itm/Music-Angel-M...item43af992725
I don't need anything like that. My current 50wpc SS "ampliceiver" is quite enough.
Old 17th January 2013, 09:09 PM   #19
cogitech's Avatar
jeff
Yes, my room is large and I do use some significant watts sometimes. The idea of having bandwidth-limited OPTs is not attractive to me. Without reasonably deep, rich bass, I'd almost rather not listen.
Old 17th January 2013, 09:15 PM   #20
Mine is called a MingYue Mini from eBay. It comes with 6N1 driver tubes and 6P14P output tubes. I replaced with Amperex 6DJ8 and GE EL84s, but the stock 6N1s are actually very good.
Receivers are often overrated for power. "50W" is at best 20W rms into 8 ohms before onset of clipping. A push-pull EL84 will give just slightly less output in the real world.
TooB NooB: Options?Hide this!Advertise here!
toob noob with GE 5670 and I'd like to do something with it. Help? danielwritesbac Tubes / Valves 46 10th February 2011 07:04 AM
Yet another do-nothing tOOb hack. kenpeter Tubes / Valves 17 21st October 2009 03:41 AM
Noob and toob genmin Introductions 1 21st January 2009 11:18 PM
Transformer Coupling and Headphones? (Toob Noob) GD3 Tubes / Valves 10 20th May 2006 12:30 PM
Noob Toob Question Beau Tubes / Valves 14 10th November 2003 07:13 AM
Copyright ©1999-2017 diyAudio
