Old 14th January 2013, 05:10 PM   #1
Default Pentode curves for GU 50 SE amp with 700V B+
hi I have breadboarded a GU 50 SE amp in pentode mode.B+ is 700V G2 is 250 Volt and my transformers Ra is 2,5k.I know that Ra is a bit low for that but the transformer is a left over from some other project. At the moment I use a 470 ohm resistor with 220uF for cathode bias,but I want to calculate the right resistor.Unfortunately i can only find triode curves but i need them for pentode mode.
Old 14th January 2013, 08:58 PM   #2
jazbo8's Avatar
http://www.mif.pg.gda.pl/homepages/f...018/g/GU50.pdf
Old 14th January 2013, 09:46 PM   #3
es345 is offline es345  Germany
Ub=700V is used for PP class AB, you will not get satisfying result for SE operating mode.
If you want to use pentode mode: Just as a top down estimation you should go to B+ of about 400V, GU50 operated at about 80-100mA . Then you could use your OT with 2K5. Looking to the datasheet you need a bias of about 25V. I would start with Rk of 270 Ohm.
Have a look here Help with these Russian GU50 tube amplifier (GU 50 SE in Triode mode, this might be a better solution)
Old 14th January 2013, 10:00 PM   #4
jazbo8's Avatar
Originally Posted by es345 View Post
Ub=700V is used for PP class AB, will will not get satisfying result for SE operating mode.
Also curious how the B+ was arrived at without a datasheet in the first place
Old 15th January 2013, 12:55 AM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Here you go:
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 15th January 2013, 05:42 AM   #6
Default Some more
First the B+ was 350V but with a voltage doubler it arrived at 700V
Ik is about 55mA at the moment.Ig2 is about 2,5 mA.I just wanted to try it,because i have a bunch of GU 50.I have to say that I use it as a guitar amp,so a certain amount of non linearity is very welcome.As driver tube I use a 6J9P at the moment.
I also tried triode mode but pentode sound is better (and more powerful of cours).Anyway many thanx for your thoughts and of course the data sheet link.
Old 15th January 2013, 05:43 AM   #7
Default Sorry
Originally Posted by Wavebourn View Post
Here you go:
Wavebourn your link dosen't work
Old 15th January 2013, 06:23 AM   #8
funny thing,now it works
Old 15th January 2013, 07:37 AM   #9
davorin is online now davorin  Croatia
Now not working!?
Old 15th January 2013, 08:20 AM   #10
Default I meant
Originally Posted by davorin View Post
Now not working!?
wavebourns link.The amp is working at all
Simple SE GU-50 Einric Tubes / Valves 49 3rd June 2012 09:13 AM
Building new GU-50 stereo amp... Wavebourn Tubes / Valves 129 4th August 2011 04:26 PM
GU-50 PP amp project - Any favs? DaveInVA Tubes / Valves 7 31st March 2010 04:03 PM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 06:10 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Copyright ©1999-2013 diyAudio
