Pentode curves for GU 50 SE amp with 700V B+ - Page 2 - diyAudio
Old 15th January 2013, 04:11 PM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by usbekhistan View Post
wavebourns link.The amp is working at all
It is right-handed triode connection. But the same trick with local feedback from anode of output pentode to anode of driver pentode can be used, to get pentode power and even better than triode linearity and even lower than triode output impedance.
The Devil is not so terrible as his math model is!
Old 15th January 2013, 08:40 PM   #12
Ejam is offline Ejam  Australia
Default A little confused
Waveborn
A little confused, are you talking about operating a GU50 as a right handed triode with plate to plate feedback or your Pyramid VII push pull circuit with GU50 as a pentode and plate to plate feedback?
Also your link does not work.
A further question if I may, you make reference to the GU50 operating best at high voltages, can you elaborate further on this. Would be much appreciated.
Old 15th January 2013, 10:03 PM   #13
Wavebourn's Avatar
Ejam;
if you look at curves you will see why I make reference to the GU-50 operating the best at high voltages. Pay attention at curves bent on the left side, i.e. at higher currents/lower voltages. It is obvious.
Negative feedback linearizes any tube no matter works it in SE or PP amp.
Let me attach the picture here if it does not show for some IP addresses.
Old 16th January 2013, 02:58 AM   #14
Wavebourn
Yes, thank you for pointing out the obvious, but from 400V up the curves are essential flat with little variation. Granted the closer to 400V, a steeper loadline is needed to avoid the lower voltage curvature. What I was alluding too, and perhaps did not express it rather well, was that in several previous posts you recommend 800V. So why not 700 or 600V with a steeper loadline (accepting less power of course) ? Is there something special about 800V or as they say is it a sweet spot for the GU50 ?
Ejam
Old 16th January 2013, 05:30 AM   #15
Wavebourn's Avatar
Why 800? I attached the picture especially for you, did you ever look at it? It is 500V there.
Old 16th January 2013, 05:40 AM   #16
Default Look
at this,it was discussed at another thread here on diyaudio.http://i19.photobucket.com/albums/b1...gu50semine.gif
I used similar feedback option for me,of course my driver tube is a 6J9P.The whole thing is working for some days now very well (with 700 Volt B+).I can switch the voltage doubler off,so i can operate with 350 B+ as well.
Old 17th January 2013, 08:02 PM   #17
jazbo8's Avatar
Which one sounds better to you?
Old 18th January 2013, 06:37 AM   #18
Default I guess
you mean the voltage.Of course 700 volt sounds better
Old 20th January 2013, 08:57 AM   #19
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Originally Posted by Wavebourn View Post
Ejam;
Is there an IRF equivalent for the mosfet FQPF3N80C ?
GU-50 PP amp project - Any favs? DaveInVA Tubes / Valves 27 18th April 2016 08:03 PM
Building new GU-50 stereo amp... Wavebourn Tubes / Valves 130 7th December 2014 09:27 PM
Simple SE GU-50 Einric Tubelab 49 3rd June 2012 09:13 AM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 06:10 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Copyright 1999-2017 diyAudio
