Tube operating points help - diyAudio
Old 13th January 2013, 11:38 PM   #1
mixelle is offline mixelle  Ecuador
Default Tube operating points help
I am trying to design an amplifier for electrostatic headphones. Since it would be using high voltages I prefer to ask for help instead of experiment while finding the operation points for the output tube.
The idea is to use the sections of a 6BL7gta in push-pull sort of like this amplifier by Mr. Gilmore All-Triode Direct-Drive Amps for Electrostatic and Electret Headphones | HeadWize
The goal is to have 1400 volts peak to peak stator to stator capacitively coupled to the headphones. Since I yet have to design the phase splitter there is absolutely no constraints on gain, power supply voltage or if I need to use fixed bias.
I have built several amplifiers and designed a single ended tube amp. But this would be my first push pull project for design so I am learning.
Old 14th January 2013, 01:22 AM   #2
DUG is online now DUG  Canada
Seems a bit much for headphones.
There is a very informative thread in the ESL/Exotics about ESL headphones that might help your design.
What you are doing is also on my (big) list of projects to do someday. (only I was going to try HV MOSFET's)
Keep us posted.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 14th January 2013, 02:40 AM   #3
Keep us posted.
Actually is not that much, here is a list with the voltage ratings of several amplifiers. 1400v p-p is the rating for the Stax T1 and the KGSS
Electrostatic Amplifiers Voltage ratings
Old 14th January 2013, 04:43 AM   #4
Interesting
Old 14th January 2013, 04:55 AM   #5
Chris Hornbeck's Avatar
How much capacitance do you need to be able to drive?
All good fortune,
Chris
Old 14th January 2013, 12:34 PM   #6
All good fortune,
Chris
I am modeling the amp around the Stax SR-307 so 120pF according to their datasheet
Old 16th January 2013, 02:25 AM   #7
OK. Check my math: Max slew rate (at zero crossing at 20 KHz) is 2.8 exp8 V/S meaning a peak charging current of 33.6 mA. Here V/S = I/C.
All good fortune,
Chris
26 Driver Tube for 45 - Operating Points eeyore Tubes / Valves 26 7th June 2017 09:19 PM
6sn7 operating points AudioGeek Tubes / Valves 24 2nd February 2017 09:44 PM
Operating points theory... lt cdr data Tubes / Valves 3 29th June 2011 10:34 AM
ECC99 operating points? skyraider Tubes / Valves 6 22nd September 2005 08:13 AM
Copyright 1999-2017 diyAudio
