OTL Heater Questions - Page 3 - diyAudio
Old 16th January 2013, 01:40 PM   #21
DF96 is offline DF96  England
"Telegraphic"?
Many valve data sheets specify a maximum DC resistance between heater and cathode of something like 20k, with specific exceptions (e.g. LTP). Those which don't specify it are almost certainly assuming a grounded heater chain, as was the normal practice in the valve era. No valve electrode should ever be left floating.
Old 16th January 2013, 01:58 PM   #22
cnpope is offline cnpope  United States
Originally Posted by DF96 View Post
"Telegraphic"?
I just meant it was a little economical with the words
Thanks for the clarification.
Chris
Old 16th January 2013, 02:16 PM   #23
Sorry. Some people tell me I am too concise with words.
Old 16th January 2013, 04:47 PM   #24
In the heater design I uploaded there is no DC connection of the filament supply to ground in order to relieve voltage stress between the filaments and the cathodes of the tubes. Nor is it an absolute that such a connection is required I have built and seen many amps without such a connection and they have worked for years without any issues. however a AC connection is supplied in order to help minimize high frequency parasitic oscillation from these same elements which can cause considerably more damage. I have this same exact set up in an OTL amp that has been work for 6 years with the same tubes.
Which is why my original lose of brain power made me question my original idea at the start of the thread on such a heater supply using mixed tubes and mixed voltages as such a setup is clearly shown in my second upload and has worked fine for years so I was just wondering why it could not work the way I showed in my originally uploaded schematic is this one works.
Old 16th January 2013, 06:07 PM   #25
No DC connection is just as likely to cause voltage stress, as there is nothing (apart from heater-cathode insulation, capacitor or transformer insulation breakdown) to stop the heater from acquiring an electric charge. Maybe it is daft of me to assume that valve manufacturers understand their own products.
Heaters may, on rare occasions, be the feedback path for RF parasitic oscillation. If so, you would need more than just one cap to stop this.
Old 16th January 2013, 06:28 PM   #26
Originally Posted by desperateaudio View Post
I
I think it was already more or less addressed in previous responses, but the crucial thing is that each tube in a single heater chain should require the same current. A 12AX7 with series-connected heaters requires 150mA (at 12.6V), a parallel-connected 12AX7 requires 300mA (at 6.3V), and a 7n7 requires 600mA (at 6.3V). So although the individual "desired" voltages all add up to what you want, the currents are wildly different, and so the actual distribution of voltages will be way off what is wanted.
You could get the currents right if you paralleled both 12AX7 tubes so that they need 600mA total (at 6.3V), and then connect in series with the 7n7. But then you'd need something like a 12.6V supply instead. (And the zener trick I mentioned before would be a good idea, since very likely the 12AX7 tubes would heat up faster than than the beefier 7n7.)
Of course, if the tube line-up you mentioned is for just one channel, so that actually you need another set for the other channel too, then chaining the other set in the same style, and then chaining the two sets in series, you would get to the 25V of the power supply you mentioned in you original posting.
Chris
Old 16th January 2013, 07:50 PM   #27
Im gonna disagree with you here and leave it at that.
Old 16th January 2013, 08:11 PM   #28
Chris
I understand where you are coming from but again here is the real world fact. That second schematic I posted in the thread has tubes of both varied voltage and current and it works fine and has worked for years that way. This afternoon I turned her over and powered it up check voltage and current consumption at varied points and the start pull down different was slight with no extreme hogging from any tube. So I get what the books say but I have it working here in my living room feel free to stop on by
And since I started this thread I have located many other heater arrangments that work the same in both DC and AC arrangments with varied tubes and volatges.
So why does it work on my second posted schematic? Is it the fact that the 12XX7 tubes are in their own line parallelled to the others? What?
Old 16th January 2013, 08:26 PM   #29
Yes, that is the crucial difference. In a given heater chain, the same current flows through each element in the chain. So if you have a mixture of tubes requiring different currents in the same chain, then some will be getting too much, and some too little. In your second schematic, each chain contains tubes whose required heater currents are identical. The fact that other chains are comprised of tubes with a different current requirement is immaterial, since each chain operates independently of all the others.
Chris
Old 16th January 2013, 09:14 PM   #30
Chris
than this should work would you agree?
Power supply, heater questions... HVfanatic Tubes / Valves 9 22nd December 2012 10:30 PM
Rozenblit 6as7 otl questions Klimon Tubes / Valves 15 30th January 2011 11:03 AM
OTL questions Fuling Tubes / Valves 49 16th July 2008 09:07 AM
heater supply questions jarthel Tubes / Valves 9 13th June 2006 09:42 AM
Copyright ©1999-2017 diyAudio
