diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   regulated (http://www.diyaudio.com/forums/tubes-valves/227720-regulated.html)
orion rob 13th January 2013 07:01 PM
regulated
not well versed in reg tubes but found a neat concept with an 0c3 but need to learn how it works. i have a realistic SAF-24D that has a plate over voltage problem that i temporarily used a stack of 10 watt resistors to calm down but are now hindering output potential and taking away from low end impact of the amp. i wish to find an appropriate value reg tube to put in line as i think it will be more efficient with current and allow for more headroom in the amp. still new at the tube thing but i have a basic understanding of how this stuff works. any comments are appreciated and thak you in advance.
orion rob 13th January 2013 07:16 PM
the amp runs 6BM8's for the outputs and the plate value can not exceed 390vdc but after the rectifier tube i can get swings of 410,430vdc depending on current demand from outputs. the transformer for output seam matched and cant find any failed pieces
Resources saved on this page: MySQL 18.75%
