6n11 tube headphone amp
Old 13th January 2013, 03:05 AM   #1
dobiejoe is offline dobiejoe  United States
Default 6n11 tube headphone amp
6n11 tube headphone amp. No sound from one side. Both main power chips are 24V and heater amps are putting out 6.9V. Any help would be great. I am thinking the main verable reisiter and I should upgrade all the resisters to 1% metal.
The numbers with input being used, no output,
pin 1 200mv with steady rise in MV range only
pin 2, 22MV
pin 3, 200MV
pin 4, 6.9V
pin 5, 36MV
pin 6, 12.06V
pin 7, 20MV
pin 8, 380MV
pin 9, 0V
Any Idea's?
Old 13th January 2013, 09:29 AM   #2
merlin el mago is offline merlin el mago
merlin el mago's Avatar
6N11 tube is the Chinese equivalent of ECC88 pin 1 & 6 are the anodes/plates so both tubes must have the same voltage so seems don't arrive B+ to pin 1 check the track if there is a burned resistor or the track have a break.
Do you have the schematic?
Old 13th January 2013, 06:36 PM   #3
orion rob is offline orion rob
Bravo 12AU7 Mods and Appreciation thread
Old 13th January 2013, 07:34 PM   #4
Originally Posted by orion rob View Post
I'm not member, I can't see nothing.
Old 19th January 2013, 01:09 PM   #5
I replaced all the reisiters with new 1/4W 1% metal film and still no output from the left side. Both heaters work. All amp chips work. I just dont get it. any ideas
Old 19th January 2013, 02:06 PM   #6
Have you checked semis: IRF510 & 2N3906?
Old 19th January 2013, 03:54 PM   #7
all four power amps work good. 6.7 to the heaters and 24 to the tube.
Old 19th January 2013, 04:53 PM   #8
If no signal in one channel inject 1KHz sinus and track with the scope where is lost the signal.
Old 19th January 2013, 05:27 PM   #9
Simon B is offline Simon B  United Kingdom
Circuit as shown below?
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 7th February 2013, 03:58 PM   #10
Still no sound out of left side.
Replaced all resisters with 1%
replaced trimmer pots with 2K and tried 10K
both heater amps work and both sides of the tube amps work.
Anything else I need to try?
6n11 tube headphone ampHide this!Advertise here!
LM3886+6n11 amp build question srinath Power Supplies 6 11th May 2012 12:16 PM
Equivalents for 12AT7 and 6N11 ? (Sense G3 headphone amp) pingfloid Tubes / Valves 22 8th December 2011 03:35 AM
6N11 tube work at 24V power supply? siliconray Tubes / Valves 16 16th October 2011 02:24 AM
2XLM3886+6N11 tube kit. srinath Chip Amps 6 19th March 2010 10:38 AM
Octal tube as headphone amp output tube yagoolar Headphone Systems 6 25th November 2006 09:11 PM
