#11 |
Check whether the output jack has a faulty connection, check the output capacitor, check the pcb for dry solder joints. As suggested above, a scope will be very useful at this point.
#12 |
anybody?
#13 |
I have no scope and can't throw parts at it all day..
#14 |
Try turning the device off, and using the ohm meter with probes as a way to check for breaks in the circuit.
With the device on, you can also input signal into it, and simply use multimeter to check for voltage, even with music playing left and right paths should still have approximately same voltage at each corresponding node. I suggest less of a "replace parts" methodology and more of a investigate what exactly is wrong with it approach. |
| LM3886+6n11 amp build question | srinath | Power Supplies | 6 | 11th May 2012 12:16 PM |
| Equivalents for 12AT7 and 6N11 ? (Sense G3 headphone amp) | pingfloid | Tubes / Valves | 22 | 8th December 2011 03:35 AM |
| 6N11 tube work at 24V power supply? | siliconray | Tubes / Valves | 16 | 16th October 2011 02:24 AM |
| 2XLM3886+6N11 tube kit. | srinath | Chip Amps | 6 | 19th March 2010 10:38 AM |
| Octal tube as headphone amp output tube | yagoolar | Headphone Systems | 6 | 25th November 2006 09:11 PM |
