Kt88 Pin alignement problem=did a mistake - Page 2 - diyAudio
Old 13th January 2013, 02:10 PM   #11
banaca is offline banaca  Canada
Originally Posted by jrenkin View Post
My guess, since you CAN bias to 20mA, is that the bias pot is the problem, or one of the other resistors in the bias circuit. Maybe check those.
I bias tubes individually with a meter on my amp ( meter integrated in the face plate) Normally I bias my kt88 to 45ma. Now all tubes bias 20ma max.
Old 13th January 2013, 02:16 PM   #12
kevinkr's Avatar
These are ultra-linear amplifiers based pretty closely on the old Williamson design and usually with ridiculously huge electrolytic caps in the supply (tube rectification by 5AR4 which usually don't live that long in these amplifiers.)
Most likely the screen stopper resistors are fried if fitted, check them first (pin 4 of each KT88) if present.
Quicksilver does not provide schematics for servicing any of their products as best I have been able to figure out. Many years ago I attempted to get schematics for a pair of monos I was servicing and was unable to do so. They aren't particularly complex, but there have been a number of variations. I no longer remember all of the details but this particular pair utilized 8417 output tubes and I converted them for KT88. (Note that I no longer service anything! )
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th January 2013, 02:25 PM   #13
[QUOTE=kevinkr;3323848]These are ultra-linear amplifiers based pretty closely on the old Williamson design and usually with ridiculously huge electrolytic caps in the supply.
Great info! Thanks!
Old 13th January 2013, 02:38 PM   #14
kevinkr's Avatar
jrenkin's comments about the bias supply are worth heeding as well, and I have just looked at that amplifier on line and realize it differs in significant ways from the much older ones I have worked on. You might also want to check the power supply voltages.
Note that the fact that you can't set the bias any higher than 20mA could indicate that bias supply voltages are too high for the tubes used. It may also indicate problems with screen resistors if indeed it is UL or with the screen supply if tetrode mode is employed.
Take the bottom cover off and snap some very detailed pictures which might give us all a clue as to what might be going on since you can't get the schematic.
I would recommend you find a good local tech unless you have test equipment and are comfortable working on tube amps which I suspect you may not be.
Old 13th January 2013, 11:59 PM   #15
I will try to post some pictures this week ( the inside) I'm bringing the amp to a tech monday night and I will give him a copie of this discussion..:-)
Old 18th January 2013, 12:46 AM   #16
The amp was checked by my tech.... I destroyed the meter... It can not be fixed... I will have to order another one from Quicksilver. ( got some help from them too. they are a good company) It is only 40 dollars for a new one. Here is a pic of the amp ( bottom) . I will be happy when it is all fixed....
Old 18th January 2013, 03:24 AM   #17
TubeHead Johnny's Avatar
Those broken key posts can be a real pain in the a*r*s*e. I bet you'll be a little more careful next time!
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz
Old 7th February 2013, 02:29 AM   #18
My amp is fixed now. We put the new meter in.... I'm happy now....
Old 7th February 2013, 03:00 AM   #19
tim614 is offline tim614  United States
tim614's Avatar
is that a Christmas light i see in there? what is that for?
Tim
" perfect imperfection "
Old 7th February 2013, 11:46 AM   #20
kstagger's Avatar
if one channel is working correctly, it can provide an easy way to check voltages and resistance. Start measuring and something will be bound to pop up.
New problem with Music Angel KT88 alecu7 Tubes / Valves 35 19th October 2015 10:12 PM
PP kt88 amp problem. ruben alstad Tubes / Valves 7 27th June 2012 03:21 PM
TL alignement question IG81 Full Range 12 2nd September 2009 04:37 PM
Quad KT88 oscillation problem chris.busch Tubes / Valves 15 26th January 2009 01:34 AM
Time alignement fundamentals Kjetil Multi-Way 28 31st March 2004 06:35 PM
Copyright 1999-2017 diyAudio
