LTspice Frustration...help, please.. - diyAudio
Old 12th January 2013, 10:14 PM   #1
Magz is offline Magz  United States
Default LTspice Frustration...help, please..
I'm spending this weekend learning LTspice in preparation for my upcoming amp build, and I'm having an issue that may well be due to total ignorance. I downloaded the program, added several model files from Intact Sim City, read the manual, and then gave it a shot. I set up a simple circuit just to test everything out - figure 1. The issue is that whenever I try to run the sim, I get the error message in figure 2. I have tried several different triode models and get the same message; when I check the files they seem to have three connections, as does the schematic, yet the system tells me the schematic has more connections than the file. I also attached the triode_nh.txt file, which is in the lib/sub folder, and contains the triode strapped 6E5P model.
I'm stumped. I'm running Windows 7 Home Premium 64-bit if that matters.
Any help is greatly appreciated. I'm sure it's something stupid that I'm missing, but sometimes you just need someone else's eyes...
Old 12th January 2013, 10:17 PM   #2
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
AFAIR, right click on the triode symbole enter the same in "Spice Model" and "Value" = triode_6E5P
Old 12th January 2013, 10:25 PM   #3
THANK YOU! I've been pulling my hair out for 4 hours!
It's working!
Thanks again!
Old 12th January 2013, 10:26 PM   #4
yagoolar's Avatar
My pleasure!
BTW, sim happened to fail after I had opened a schematic and I had to re-enter those values.
Cheers, St. Emillion 2009
Fullrange frustration! InclinedPlane Full Range 16 4th November 2007 11:27 PM
AC motor frustration.....Help! Vinyl-Addict Analogue Source 9 23rd April 2007 05:31 PM
Load line frustration eddog Tubes / Valves 8 20th January 2006 03:29 PM
Aleph 2 Frustration macka Pass Labs 6 9th September 2002 12:21 PM
Copyright 1999-2017 diyAudio
