Bias mods
Bias mods
Old 12th January 2013, 06:39 PM   #1
fredericasse is offline fredericasse  France
Default Bias mods
I will build soon my vavle preamp. Before begining my construct i would like to add an adjustable bias. Indeed, in order to change voltage i have to change two resistors : one of 660R/20W(It's expensive) and one of 4K7/11w... the process is not very convenient...
I try to discover how i can add 2 pots bias instead of the two resistors ?
Thank you in advance for your help.
ps: i have found this schematic on the web, do you think it is possible to adapt it to resolve my problem ?
http://home.comcast.net/~jbjdav26/in...ual%20bias.jpg
Old 12th January 2013, 08:42 PM   #2
DF96 is offline DF96  England
Why do you want to adjust the bias on your preamp? Do you mean the DC power supply voltage B+/HT?
What problem are you trying to solve?
Old 12th January 2013, 09:10 PM   #3
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Looks to me that the power supply you posted is intended for a power amplifier, rather than a preamp.
Old 13th January 2013, 02:03 AM   #4
Robert Kesh is offline Robert Kesh  Wallis & Futuna
Robert Kesh's Avatar
A pre amp will not need 20W resistors.
Bias is not done at the power supply, it's typically done at the cathodes.
Bias modsHide this!Advertise here!
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 22 8th May 2018 12:54 PM
Soundstream Picaso - Bias and mods question JZatopa Solid State 26 8th April 2013 06:53 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
hafler 9180 BIAS+Mods bluesmoke Solid State 25 12th April 2006 04:14 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
