Distortion rise on OPT - diyAudio
Old 11th January 2013, 09:34 PM   #1
rrrs is offline rrrs  United States
Default Distortion rise on OPT
Hi, I did post this in another thread, but got no response yet.
I am experiencing “strange” behavior on my OPT; it is Lundahl LL1691B, 20K:8ohm used with 211 tube.
Distortion (mainly 2nd order) increases a lot at higher frequency, from 2kHz up.
Here are THD measurements I did in ARTA, all at 1W into 5.7ohm load (this are measurements of actual amplifier, not just OPT):
40Hz – 0.2%
100Hz – 0.11%
1KHz – 0.11%
2KHz – 0.17%
4KHz – 0.35%
6KHz – 0.57%
8KHz – 0.78%
10KHz – 0.94%
12KHz – 1.11%
14KHz – 1.17%
16KHz – 1.14%
18KHz – 0.97%
As this is 2 stage amp using Interstage Transformer I suspected the problem might come from IT, so I did comparison removing IT and using choke loaded first stage, cap coupled to output stage; I got pretty much exactly same distortion figures.
Here is distortion spectrum, showing 10KHz in black and 1KHz in magenta; it is interesting to see that 2nd order distortion is much higher with 10KHz then at 1KHz signal while 3rd order is about the same!?
In frequency response measurement I do not see any strange peaks in that range; black line is IT coupled while magenta is choke loaded capacitor coupled.
211 output stage uses fixed bias, so output impedance of 211 should remain pretty constant across frequency range; around 3.8K at my operating point.
When testing I can hear a clearly audible sound from OPT even at 1W level and this increases with frequency; very similar to my distortion measurements. I understand that this is actually normal behavior of OPT, but is this what causes this increase in distortion and is that increase also something normal?
Old 11th January 2013, 10:02 PM   #2
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Can you hear music through the OPT?
Old 11th January 2013, 10:31 PM   #3
Never tried to input music with load resistor instead of speaker; will try and report.
But, when doing frequency response measurement (at 1W into 5.7ohm load) I can hear sort of "Pink noise" from OPT; it is not loud, but can hear it from couple of feet distance.
Old 12th January 2013, 03:25 AM   #4
Alexsk is offline Alexsk  Canada
how's distortions looks like with the higher output signal, let's say 6-8 v RMS ?
Old 12th January 2013, 04:14 AM   #5
Chris Hornbeck's Avatar
It's normal for output transformers to "sing along". And you know the ancient joke about why amplifiers hum (they don't know the words).
The output tube will make higher distortion into a reactive load than a resistive one, and the output transformer's parasitic capacitances and leakage inductance start to become significant at high frequencies. A transformer for a single type 211 is right on, or just beyond, the raggedy edge of workable over the whole audio range, so this too is normal. The lack of 3rd at 10KHz isn't too surprising given the big notch there.
All good fortune,
Chris
Old 12th January 2013, 04:15 AM   #6
Hi, it rises proportionally the same.
For example, on 5W into 5.7 ohm (5.3 V-RMS) I get:
40Hz – 0.4% THD
100Hz – 0.34% THD
1KHz – 0.37% THD
10KHz – 3.5% THD
So, at all frequencies distortion increased approximately 3 times in respect to 1W measurement, 10KHz value still being 10 times higher than 1KHz value.
When testing at 5W transformer makes pretty loud sound at higher frequencies 9abone 2-3KHz.
See attached spectrum comparing 1KHz to 10KHz, both at 5W into 5.7ohm.
Old 12th January 2013, 04:21 AM   #7
Hi Chris, just as I posted reply seen your post; makes sense.
So, basically should be normal.
What did confuse me was that I spoke to Kevin, Lundahl US distributor who built SE GM70 amp using same transformer and he did not notice any rise in distortion with frequency!?
Perhaps lover plate resistance of GM70 was less sensitive to transformer's reactive load?
Old 12th January 2013, 06:17 AM   #8
regal is offline regal  United States
I have been having the same issue with my OPT (different manufacturer), I am leaning toward the problem being too much inductance in the secondary.
Mine is a 5k:32 ohm headphone OPT. But it is similiar to yours in that the secondary has a relatively high DCR and inductance.
I have been searching for a real solution. Odd ball transformers like ours I think just need to be custom jobs. Nickle Alloy Parafeed makes a lot of since for these situtations since it allows a much lower dcr/inductance in the secondary. Problem is it is expensive.
Not saying that I am right about this, but disagree that the measurements are "normal".
I also think the transformer "singing" nneeds to be minimized because it causes the tube to distort.
Don't mean to be a sour-puss and am not knocking Lundahl at all because it is an issue for other manufacturers as well. Just as you looking for solutions to age old problems a lot of us tube guys have had been dealing with for years.
Old 12th January 2013, 07:42 AM   #9
tomchr is offline tomchr  Canada
tomchr's Avatar
On my Electra-Print OPTs wound for use with a 300B SET the THD does increase slightly at higher frequencies. Say 0.18 % at 1 kHz and 0.22 % at 10 kHz. Those trannies sing along quite loudly, actually. Louder than the Edcor CXSE25 I used to use. So I wouldn't discard the transformers just because they sing along.
Sand amps sing along too, actually. Though, they don't sing anywhere near as loud as tube amps.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 12th January 2013, 03:50 PM   #10
~Tom
That is more or less the same results i got from 300b with Audio Note EI and Hashimoto transformers.
With 2.5v output (correct?) 0.11% at 1kHz looks good, but at 16kHz whould be normal to have something like +2,3 db not +20 db distortions.
In my case at 5v RMS out to 8ohm 1khz and 20 khz are the same -44db, 50hz -40 with Hashimoto, with AN output 20 khz distortion are +2db compared to 1 khz. Again, it is 300b amp.
HTH
Distortion VS OPT impedence Nihilist Tubes / Valves 1 3rd March 2010 12:45 AM
How To rise sensitivity of aleph -x? elviukai Pass Labs 11 2nd June 2006 10:07 PM
impedence rise/amplifiers SkinnyBoy Everything Else 0 14th May 2005 11:48 PM
Reducing impedance rise? JeremyD Multi-Way 6 4th July 2003 11:58 PM
Copyright ©1999-2017 diyAudio
