How to build a transconductance tester for small driver tubes? - diyAudio
Old 11th January 2013, 04:35 PM   #1
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Default How to build a transconductance tester for small driver tubes?
I was wondering if I can convert one of my amps into a tube tester for small driver tubes. Can anyone point me in the right direction?
Old 11th January 2013, 04:41 PM   #2
kevinkr's Avatar
Take a look at this design.. I'm planning on getting one in the near future if the software is compatible with at least one of the windoz boxes I have on hand..
Here: The uTracer, a miniature Tube Curve Tracer / Tester.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 11th January 2013, 04:42 PM   #3
Whoa, that is cool! Thanks for the info!
Old 11th January 2013, 07:47 PM   #4
The software is compatible with windows xp, and windows 7, and I think also windows vista. I didn't test on windows 8. You do need a serial port, but you can also use an usb to serial convertor, see the text on the website.
Old 11th January 2013, 08:03 PM   #5
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
I think this is about as simple as they come:
The Valve Wizard
Old 13th January 2013, 01:06 AM   #6
Awesome awesome.
One thing I wonder is if I can lower the plate resistance of a 26 at higher current for an all-DHT project. The datasheets don't run the current very high.
Power Transconductance Amp with Tubes, How? CLS Tubes / Valves 27 23rd October 2015 09:12 PM
settings for 300b tubes on 539c tester TubeHound Parts 2 25th February 2014 05:58 PM
Settings for PL509, EZ80 tubes on 539c tester MateKrisz Tubes / Valves 4 3rd November 2011 09:39 PM
Bad tubes wanted for tester testing crj11 Tubes / Valves 4 17th December 2009 02:27 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Copyright 1999-2017 diyAudio
