| diyAudio Sponsor | ||
#11 |
Hello
This El GEC-30w looks really nice, but I think itīs a bit out of budget for Grabo want to spend the minimum. But if you want some traduction I can help you NO PROBLEMO. J-Y |
#12 |
diyAudio Senior Member
Hi Pascal, Icare,
I don't know about the modified GEC 30. As with most amps I believe a big part of the final quality comes from the OPT used. Which somehow reminds me of the Jadis JA30, the Yves Cochet (Cl AB1), idem for the Ampliton etc. As for Grabo, why not do a Curcio mod on a Dyna? Cheers,
Frank |
#13 |
Here is a low cost plate voltage transformer for DIY projects, $20:
http://www.meci.com/ (click on transformers, then click on "standard") Its the first one that comes up, P/N 600-0427 made by Hammond. Actually is a 300 Watt unit for normal temperature rise (the 500 W rating is for smoking hot temp. rise), weighs 10 Lbs, 120V to dual 240V windings. No electrostatic shield, so use a line filter with it. The fuse holder on top is removable. Make sure to enclose it in the chassis or a box, for safety, since it has exposed terminals.
Ohms Law V = I R |
#14 |
Hello Frank, thanks !
I don't know if for USA it is possible to buy, but for europeans, i recommend Magnetic main or output transformers http://magnetic.com.free.fr/ . Very very good !!! and low price. They are near my house and I know them very well, if you buy transformer say that ptsoundlab recommend you, it is possible that you have a better good price Cordially Pascal. |
| Blown 20watt 4.7uf on soft start board | ben62670 | Solid State | 4 | 26th June 2007 05:29 AM |
| Is this a good design? | wildswan | Solid State | 20 | 23rd May 2006 10:15 AM |
| Good design? | icebear | Tubes / Valves | 1 | 30th September 2004 12:44 PM |
| Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? | XteveX | Multi-Way | 7 | 28th April 2004 04:05 AM |
| Good amp design? | technics | Solid State | 6 | 17th June 2003 01:04 AM |
| Page generated in 0.08145 seconds (69.98% PHP - 30.02% MySQL) with 10 queries |
