What should I build - diyAudio
Old 11th January 2013, 12:26 AM   #1
Default What should I build
Hey guys, I built a 100watt tube guitar amplifier a few years ago and it sounds awesome and is still going strong.
I was looking into doing another project and am looking for suggestions. I want something that sounds great. I am really big into high quality audio. Is it possible to make a 5.1 home stereo in a tube amp? How would it sound in comparison to some of the current solid state stereos. My other idea is a 2 channel tube amp to play music from a computer or mp3 players. What do you guys think i should do, are there any kits? or layouts? What are the approximate costs. Also what is recommended for speakers?
Thanks,
Kevin
Old 11th January 2013, 01:10 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Congrats on your successful guitar amp...I'll assume it was a push-pull.....as Class A would have been kinda hard & $$$ to build.
A Home theatre 5.1 ??? Multi-channel amps tend to not lend itself to tubes much. As tubes are space consuming, Iron consuming.........& what if you go push-pull on all the channels??? My thinking is Class D with all those little compact modules neatly arranged in a case.
This leaves an amp-speakers combo for your PC. A nice little/simple class A 2A3 ......with a unique chassis to fit somewhere in your PC station.....some Fostex Full-Rangers in a pair of back-loaded horn towers........& you'll be set.
__________________________________________________ Rick.........
Old 11th January 2013, 01:38 AM   #3
2A3s are costly and so is the "iron" that's used with them. Triode wired 6V6 family tubes sound GOOD and cost less too. Go push/pull and the "iron" is reasonably priced too. A mild Class "A2" operating conditions set, as used in "Musical Machine" and "El Cheapo", yields approx. 6 WPC. That's plenty, when mated to mid 90s sensitive speakers.
BTW, people have done HT setups with tubes, but the cost to build and operate is very high.
Eli D.
Old 11th January 2013, 04:34 AM   #4
do you guys know where i can find a schematic and/or layout?
Old 11th January 2013, 05:11 AM   #5
My previous post should have said Class "AB" not Class "A2".
I've uploaded the "El Cheapo" schematic. The 'AQ5 shown is, for all practical purposes, a 6V6 in a 7 pin mini package.
Eli D.
Old 11th January 2013, 08:23 AM   #6
bayermar's Avatar
+1
and the alter-ego 6P6S can be bought for very little money, although JJ or EH 6V6GT are not particularly expensive either.
For a small computer system, a simple SE design with recycled console transformers might also work, if max. SPL and thundering bass are not a requirement.
I finished one recently: Trioded-wired 6P6S driven by 6n8s with CCS at the plate and LED bias.
I am still experimenting with some cathode feedback to get more low end out of the somewhat challenged OT but the overall performance is not too bad.
Martin
Old 11th January 2013, 03:07 PM   #7
My computer has a great audio card, and im pretty big into music. Id love to have a nice sounding system. I dont mind spending a bit to achieve this
First Open Baffle Build- Build is done harvylogan Multi-Way 11 17th December 2012 03:15 PM
Build or not to build - $300-500 budget sasav Multi-Way 19 6th January 2012 03:27 PM
What can i build? r0n22 Chip Amps 3 2nd April 2009 10:49 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Copyright 1999-2017 diyAudio
