Dynaco ST70 KIT - your opinion please
Old 27th January 2013, 12:09 PM   #21
Burnedfingers is offline Burnedfingers  United States
Originally Posted by Eli Duttman View Post
Some comments, If I may. The Triode Electronics driver board gets populated with 2X EF86s and a single twin triode. That twin triode may be an ECC99, 12BH7, or 12AU7. I advise installing an ECC99, for its high gm. High gm in designs employing GNFB, like the ST70, provides resistance against slew limiting associated with the HF error correction signal.
As the ST70 uses "fixed" bias and an instant on, SS rectified, C- supply, even the slightest delay in B+ rise is sufficient to protect the O/P tubes against cathode stripping. A NTC inrush current limiting thermistor provides the short delay needed, if either SS diodes or a directly heated vacuum rectifier are/is employed in the B+ circuitry.
IMO, it's perfectly acceptable to SS rectify ST70 B+. You turn the excessively "tall" B+ rail from a liability into an asset, by employing combination bias. "Stand" the cathodes of each O/P tube pair on a 100 Ω/470 μF. network. A very convenient "idle" current test point is available and the original single bias adjustment for each channel is quite satisfactory. Matching requirements are reasonably relaxed. As is always the case, closeness in gm is a must for each pair. However, small differences in cathode current are acceptable.
An additional benefit of SS rectifying the B+ is the cooler running power trafo obtained by holding the value of the 1st filter cap. down to say 10 μF. Replace the overworked C354 choke with a Hammond 159T.
Cathode stripping???
You have got to be kidding.
Old 3rd February 2013, 03:00 PM   #22
zimmer64 is offline zimmer64  Switzerland
zimmer64's Avatar
I finished the kit today and the amp is playing sweet music! Special thanks to SandyG for recommending tubes4hifi. The kit is realy great, the manual is precise and easy to follow. Bob packages all parts in individual bags, which makes the assembly a breeze. And, Bob supported me, when I needed it. I can definitely recommend this kit if you are after a Dynaco ST 70 kit. Being a DIY newbie myself, I can also say that the kit is suitable for beginners. If you can solder and operate a srewdriver you're all set.
Soundwise I like the ST 70 better than the Gainclones that I did before. Thanks again to the community here in helping me make this decision.
Best
Michael
Ps: I have taken lots of photos along the build process and put them in my blog. Should you be interested, check it out. (I payed Wordpress now to remove the ads, so you wont get bothered.... ).
Michael's Project Page
Old 3rd February 2013, 06:06 PM   #23
SandyG is offline SandyG  United States
SandyG's Avatar
Michael -
Glad you got it going. It's a great amp and sounds very good. I was greatful for how Bob packs all the parts and the instructions and some of the extras you can get.
Enjoy!
Sandy
Old 3rd February 2013, 08:16 PM   #24
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
My opinion: if somebody wants to own Pyramid with golden chassis, I would be glad to know where to order such chassis. :-)
At least, golden mirror behind tubes would look gorgeous.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 4th February 2013, 03:59 AM   #25
SandyG's Avatar
Wavebourn -
Did you post to the wrong thread? I think this might have been for the thread on the 24k 'Special Expensive' Edition of the ST70.
Sandy
Dynaco ST70 KIT - your opinion pleaseHide this!Advertise here!
FS: Welborne Labs Alan Kimmel Mu Stage Driver Kit for Dynaco ST70 ST-70 e.lectronick Swap Meet 7 6th May 2009 04:30 PM
DIY Dynaco ST70 wingking3000 Tubes / Valves 2 25th July 2008 11:20 PM
Bias adjustment on Dynaco ST70 ghisdal Tubes / Valves 1 12th March 2007 09:05 PM
Dynaco ST70 clone Tekko Tubes / Valves 8 9th April 2005 03:02 PM
Dynaco ST70 cwteoh Tubes / Valves 14 27th May 2004 07:07 AM
