#11 |
I use 20kv 200 deg c rated stuff off e bay, seems ok.
enzo |
#12 |
The voltage rating for the TCSS is 10k. The actual model number of the wire is 10kTCSS. >To: Kimber customer support > Please provide the voltage rating for the TCSS/19 wire. I would like > to use it in an audio amplifier with a B+ supply of 1250VDC. I can use it > with a teflon sleeve if required. > |
#13 |
expert in tautology
I'd not use rubber or PVC, since it degrades over time.
Test lead wire will crack and develop pin hole defects too... the asian stuff is especially not so good. I prefer suitable insulated wire with a suitable (usually, but not always) PTFE spaghetti sleeve over that. More reliable, imo. _-_-
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#14 |
Once the circuit is built and in place why would the plate cap wire ever move enough to be of concern?
Just slide a length of 600V or greater heat shrink tubing over it, shrink it, and call it a day. |
| need binding posts for #4 wire, mount on steel plate | cyclecamper | Parts | 12 | 20th December 2011 08:20 PM |
| Fuse Clip for Small Plate Cap Use | wrenchone | Tubes / Valves | 12 | 12th February 2011 11:17 AM |
| cap wire lead covers | skipper | Tubes / Valves | 7 | 15th May 2009 09:51 AM |
| Plate to Cathode Cap -- what's this?? | Buckeye Sound | Tubes / Valves | 14 | 13th October 2006 09:48 AM |
| 350w plate amp,whats this wire! | mikee12345 | Multi-Way | 17 | 4th May 2004 09:43 AM |
