Old 16th January 2013, 05:39 AM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
On such low B+ you have to drive it in AB2, look at curves, otherwise output power is limited by saturation.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 16th January 2013, 07:51 AM   #12
palmas is offline palmas  Portugal
Originally Posted by Junm View Post
I've tried plotting the loadlines for GU-50 PP triode for B+=400v and Ia at 60mA. I also do calculations based on Turner Audio computation and assumption and i came up with the attached.
I just wandering why is it that the AB1 power is lower than Class A power...Does it mean that the tube is only a PP class A? or Am I doing the correct calculations and plotting? any comments please?
is it just my eyes or you mixed up the A point with the AB point?
AB has a little more swing, as I see it, so a little bit more power
Old 16th January 2013, 08:37 AM   #13
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Thanks,
What particular curves I will refer to? I'm just learning to look the curves and a little bit confused.
So 400v B+ in triode is too low? does the b+ reffered to is the B+ from PSU or the one measured on the GU-50 Plate?
I will try B+ 450v and see what it takes...
Old 16th January 2013, 08:50 AM   #14
jazbo8's Avatar
Thanks,
B+ refers to the supply voltage, for triode you can use the chart on the lower right corner - but you alrady have one - the one that you posted earlier is a triode chart. IMO, GU50 is not the ideal candidate for your PT and OPT combo.
Jaz
Old 16th January 2013, 08:53 AM   #15
Tony is offline Tony  Philippines
Tony's Avatar
I'm a little bit confused on plotting loadline for GU-50 triode mode. can somebody help me draw loadline for 10k load and 450v B+..TIA
there is a good explanation found on RCA tube manuals, can be downloaded at Pete Millete's site.....Tube Data
Old 16th January 2013, 09:19 AM   #16
Tony's Avatar
at idle you are running your tubes at 24watts or 48watts total and you are in classA region, not a bad thing...not much of a concern....
your grid bias of -70volts will require more from your drivers.....i am curious how you will supply the needed drive....
Old 16th January 2013, 03:26 PM   #17
Wavebourn's Avatar
Right, saturation of driver is one more thing that can cause such limitations, except saturation of output tubes. It can supply enough swing for class A (lover bias voltage, lower swing required), but saturate on lower swing than is needed for class AB (higher bias, and higher swing is needed). Since transconductance of output tubes is higher on higher current, you are getting more power from the same output from driver.
Old 16th January 2013, 11:13 PM   #18
jazbo8's Avatar
I don't think the load line for Class A is correct, at least not with B+ of 400V... See if the below makes sense, I also changed the bias point a bit, hope I got it right...
For Class AB1
Class B Calculation
Irms = 0.115 / SQRT(2) = 0.081
Po = 0.081^2 x 2500 = 16.53
Iavg = 2 x 0.081 / 3.14 = 0.052
Pdc = 400 x 0.052 = 20.71
Pd = Pdc - Po = 20.71 - 16.53 = 4.18 (both tubes)
Class A Calculation
Ia = 400 / 5000 = 0.08
Ia' = 0.08 + 0.03 = 0.11
Vt = 260
Vrms = (400 - 260) / SQRT(2) = 99
Po = 2 x (99^2 / 5000) = 3.92
% into Class A = 3.92 / 16.53 = 23.71%
For Class A
Vrms = (400 - 240) / SQRT(2) = 113.14
Po = 2 x (113.14^2 / 5000) = 5.12
Old 17th January 2013, 12:01 AM   #19
Junm's Avatar
Thanks for all your comment guys...
@Jazbo...I can't see the picture you attached...i hope you drawn your loadlines for me to refer...I greatly appreacite it... kindly re attach the picture...
Okay guys...how about reducing the OPt impedance to 5k by making the 16ohm secondary for 8 ohm speaker...does it make sense?...i just dont know if the opt can handle the primary current needed and how it will affect the bandwith?.
Old 17th January 2013, 12:07 AM   #20
jazbo8's Avatar
Sorry, I thought I attached it... might be dropbox acting up. Yes, 5K would be a much better load, but may exceed your OPT's 20W rating.Try play with the curves a bit to make it work...
GU-50, GM70 and KT88 nina Tubes / Valves 44 27th September 2012 05:14 PM
5k:8 ohm vs. 10k:16 ohm output transformer. What is the difference? Austin Translation Tubes / Valves 109 24th July 2012 01:56 AM
GU 50 monoblock gedd Tubes / Valves 8 21st October 2011 10:08 AM
GU-50 PP amp project - Any favs? DaveInVA Tubes / Valves 7 31st March 2010 04:03 PM
Use of 12j1l and gu-50 tubes gemby Tubes / Valves 6 26th October 2008 09:56 PM
Copyright ©1999-2013 diyAudio
