How to calculate output transformers - diyAudio
Old 8th January 2013, 05:31 PM   #1
merlin el mago's Avatar
Default How to calculate output transformers
How to calculate necessary spec for output transformers:
-For example heaphone amp for HD600 300 Ohms?
-Other example line amp for power amp with input impedance 2K?
-linea amp for tube power amp with input impedance 100K?
-Other loads?
What I need is to know how can calculate, so I learn and also can be calculate for future projects.
Help will welcome.
Old 8th January 2013, 09:29 PM   #2
Zibi is offline Zibi  Poland
.turneraudio.com.au/education+diy
Old 9th January 2013, 09:51 AM   #3
Thanks for the link, I'm lost with a lot of information, could you be more precise?
Old 9th January 2013, 09:59 PM   #4
FullRangeMan's Avatar
I once read in an technical article that 1 turn/spin in the primary winding reduce the impedance in 1 ohm, but I dont know if this is true.
I also will wait the experts opinion in this topic.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 23rd January 2013, 05:30 PM   #5
Can you understand Portuguese? try this site, it has a full course on output transformers! Already have ready calculations of transformers for power between 5watts and 40Watts!
link >> Transformadores de saída para Audio Valvulado / Output transformers for Tube Amplifiers
Old 23rd January 2013, 05:50 PM   #6
http://www.geofex.com/article_folder...es/xformer.htm
Old 23rd January 2013, 05:55 PM   #7
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Search for Wolpert transformer design, I believe anywhere in this site.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 24th January 2013, 12:01 AM   #8
Valeu Edson, mto obrigado por este Link, ñ conhecia este site, vou dar uma lida com carinho.
Abrç
How do I calculate output power? mario13 Tubes / Valves 13 27th July 2010 01:56 PM
How to calculate gain and output impedance? RogerGustavsson Solid State 1 7th June 2008 05:09 PM
How do I calculate the maximum output of a driver? The Paulinator Subwoofers 2 21st May 2008 01:00 PM
How calculate the output power Progg70 Solid State 17 11th April 2007 09:05 AM
How calculate the output power Progg70 Solid State 2 19th October 2005 03:57 PM
Copyright ©1999-2017 diyAudio
