Cathodyne fet buffered balanced line out
Old 8th January 2013, 03:09 PM   #1
Michael Allen is offline Michael Allen  United States
Default Cathodyne fet buffered balanced line out
I built a preamp with an edcor 600ohm output transformer driven by a cathode follower for XLR balanced out. However, in the rack unit I cannot get the transformer to stop picking up power transformer flux regardless of where I place it. It has no shielding so it's an easy target.
I was thinking about forgoing the transformer but still wanting balanced line out. I googled bits and suggestions but nothing concrete about using a cathodyne with mosfet source followers to buffer the outputs. To me it sounds reasonable, anything I should be aware of? What kind of current will these things be pulling? I have some LND150 here, but can get some IRF820 at work. I modeled it in LTSPICE and it looks like they pull around 5 ma and the circuit works, but I do not know how to measure output impedance to see what it all ends up looking like.
Any comments?
Cathodyne fet buffered balanced line outHide this!Advertise here!
Buffered, balanced gainclone kits. jamikl Chip Amps 2 1st March 2009 03:51 PM
passive buffered line drive plans wanted! shaun5 Chip Amps 0 11th December 2005 09:40 PM
Audio Balanced Buffered Line Driver Quattor Solid State 10 24th October 2005 04:52 PM
Substitute FET IRF610 for balanced Zen line Stage xenofex Pass Labs 5 1st January 2005 07:22 PM
line splitter (active/buffered) advice? newmz Solid State 0 23rd April 2003 06:35 PM
