807pp + input phase splitter
Old 12th January 2013, 01:20 PM   #41
lcsaszar is offline lcsaszar  Hungary
Is it related to the fact that Vg2=300V, Va=600V max according to the spec sheet, and 300V is too low B+ in triode mode for getting optimum performance?
Old 17th February 2013, 10:12 AM   #42
6J7 is offline 6J7
6J7's Avatar
Default paraphase ?
Hi
I received the silver mica's caps, 100pF to 1nF for the input PI trans (Sowter 8920). It didn't cure the problem, still ringing.. just for testing purpose I tried with a LL1681 (MC input transformer not intended for this use), all is well, no ringing, sinewaves, triangles, even squares are clean.
Now I would like to try an old and simple PI, the paraphase. This one seems to be a little bit different. 1M in // of the 270K and connected to ground through the 270K.
Any comment ? no pot needed to adjust the gain of the second half triode ?
Is this PI dangerous in case of overdriven PP ?
Last question, generally speaking, does a PP triode connected has interest ? every time I tried UL, it sounded better to my ears, despite the DF issue (no feedback yet).
OPT are from Quicksilver mini-mites, good ones ?
Thanks.
807pp + input phase splitterHide this!Advertise here!
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 06:51 PM
Phase splitter and balance input johnmarkp Tubes / Valves 2 30th July 2010 03:34 PM
Optimizing a 807 PP amplifiers input stage and phase splitter... pauldune Tubes / Valves 4 26th November 2009 11:24 PM
Possible group buy of Lundahl input/phase splitter transformers. Shoog Tubes / Valves 51 14th November 2008 12:45 PM
Phase Splitter as input stage Peter Menting Tubes / Valves 21 3rd January 2005 09:48 AM
Copyright ©1999-2017 diyAudio
