leak st 20
leak st 20
Old 8th January 2013, 10:56 AM   #1
Edwar65 is offline Edwar65
Question leak st 20
Hi all, just aquired one of these privately, which has been restored by classique sounds, Id like to ask if these are happy to be run with an unventilated cover on base or would they be better with a ventilated base?
Just that I got some kids in house and don't want them sticking there pinkys anywhere where they shoudn't!!!
Also what should the tranny voltages be as in cardiff mains is around 240v and these are set at 220/230?
thanks
tom.
Old 8th January 2013, 12:03 PM   #2
Shoog is offline Shoog
Shoog's Avatar
There will be very little through ventilation due to the lack of holes in the top plate so it won't make a huge amount of difference. However its just as easy to make a bottom cover out of punched metal sheet which will preserve the ventilation that there is.
As to mains - when I had one we tended to have high mains voltage at night and it never caused an issue for me. However there should be an adjustment plug on the mains transformer which can be set for an input voltage of 245VAC if you are concerned.
Shoog
leak st 20Hide this!Advertise here!
Attenuator for passive pre (LEAK ST 20) vincula Tubes / Valves 9 11th October 2012 05:03 PM
Help with diagnoses for leak 20 PLEASE mikemac Tubes / Valves 8 7th April 2012 08:16 AM
Leak Stereo 20 questions Johan Potgieter Tubes / Valves 23 30th April 2006 11:57 PM
Motorboating in leak 20 bronto64 Tubes / Valves 5 13th August 2004 10:49 AM
Mods on leak stereo 20 bronto64 Tubes / Valves 22 26th April 2004 08:27 PM
